07-08-2017, 10:29 AM
Adding hitch receiver
Has anyone added a two inch hitch receiver to their bumper? I'm looking to carry two bicycles. Decal on bumper says it will void warranty.
07-08-2017, 10:32 AM
I've just done it... but I did my research, reinforced the bumper, and our trailer is out of warranty.
http://www.forestriverforums.com/for...-136972-2.html
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
07-08-2017, 12:42 PM
Don't waste your time trying to use the square tube bumper on the back. Put a receiver hitch on the rear. You can buy a universal RV hitch from Amazon through Curt or other manufacturers. Also through Etrailer.com. Will cost some to have it installed, but you won't have to worry about it cracking or breaking off. My assumption would be you also have a spare tire carrier bolted to it. I had a welder put mine on and reinforce the square tube where it carries the spare. Bike racks put a lot of leverage on their receivers and they bounce a lot. Just my recommendation.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
07-08-2017, 01:48 PM
King of the Road
X2 this. I have a friend that works for a big rig trailer shop and he put in a hitch receiver for me. Frame welded and enhanced, can carry 500 lbs or tow 1500.
Have done both, with motorcycle carrier for small dirt bike (300 LBS) and kendon stand up motorcycle trailer triple towing an Electraglide bagger (1200 lbs).
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
07-08-2017, 07:31 PM
Novice Travel Trailer Guy
Not recommended unless you do your engineering correct. Not only depends on what your carrying but the effect the added load puts on you set-up. Adjustments will be needed.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
07-08-2017, 07:38 PM
King of the Road
So as an engineer, what adjustments would you recommend?
2016 Crusader Lite
Single slide
07-08-2017, 07:53 PM
See posts #2 and #12 here for the receivers I had welded to the frames of my Roo 19 and Mini Lite 2503S:
http://www.forestriverforums.com/for...oo-107358.html
Others have gone with Safety Struts like these:
https://www.mount-n-lock.com/mnl-car...bumper-failure
and added a bolt-on receiver like this:
Another option is a bolt-on-to-frame receiver like this one from eTrailer:
https://www.etrailer.com/RV-and-Camp...urt/13703.html
Don't just bolt something to the bumper. That's tempting fate.
2011 Traverse LT, 3.6L, FWD
07-09-2017, 08:47 PM
You must be a mechanical engineer.
07-09-2017, 08:54 PM
King of the Road
Not me, I'm just another retired guy.
2016 Crusader Lite
Single slide
07-09-2017, 10:17 PM
I bought one that bolts on to the pin box. No welds required. It was from a bike shop in Quebec
Works fine but a little pricey
07-10-2017, 06:54 PM
If you take a real close look at the welds and the material of the OEM bumper you wouldn't even mount the spare tire to it, I had my bike rack mounted to the pin box with a custom mount but need to move it because I'm mounting a cargo rack to the pinbox instead, I removed their bumper and replaced it with one I built(4"x4"x3/16" wall SQ tube and the mounting tubes are 4"x3"x3/16" wall that run 24" under the frame)much better then original and I don't worry about the bikes falling off
I also beefed up the lower end of the bike rack as well.
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2019-41/2020-lots planned
2017-51/2018-55
2015-57/2016-52
07-10-2017, 07:22 PM
King of the Road
Outstanding. Looking good.
2016 Crusader Lite
Single slide
07-20-2017, 02:24 PM
i brought my 5th wheel to a welding shop and had the oem bumper removed and re-welded and also added reinforcement to it. I had them weld 2 pieces of angle iron to the frame and also to the bumper. I only carry 2 bikes on my bike rack which is just bolted to my oem bumper.
2006 F-250 CCSB 4x4 6.0 Powerstroke
Air Lift 5k bags w/ onboard compressor
2022 Keystone Raptor 351
B&W Companion
07-27-2017, 09:13 PM
I have a Tracer Air 238 I want to attach a cargo rack for my generator.to the rear bumper after checking the quality of the welding I am surprised it is still attached.I am a retired welding inspector just about every welding flaw in the book
Is well represented in those weldments
07-27-2017, 09:36 PM
If you decide to mount to the bumper and no support to the frame, just look at the welds holding the bumper on...guarantee you'll change your mind and have something frame mounted. There are vids out there of the bumpers being ripped from the welds by the constant vibration of bikes on a rack bolted to the bumper.
