Old 11-29-2020, 08:11 AM   #1
Breaker Blowing
We have had to replace the same breaker 3 times already and it has blown again.
The best we can tell it only works the overhead lights above the recliners.
Had it to the shop but since we had replaced it beforehand they couldn't find anything wrong.
Could this be an electrical or fire hazard?
romreader is offline   Reply With Quote
Old 11-29-2020, 08:13 AM   #2
Mr. Dan's Avatar
Breaker? Could you be talking about a fuse which is usually associated with 12vDC lights.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 11-29-2020, 08:38 AM   #3
Head Rambler
I'm with Dan, sounds like you're talking about a fuse.
Can you tell us the rating of the fuse? It should be stamped into the top of the fuse. Should be a 15 amp or something close.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 11-29-2020, 08:46 AM   #4
Are the overhead lights mentioned in the first post LED or incandescent lights? That would make a big difference in the current draw for that circuit.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 11-29-2020, 11:23 AM   #5
rracer5's Avatar
X4 Agree with all the above. More info is needed such as; what year, make & model is the RV? Are the lights 12v or 110v? Are the recliners in a slide? If they are in the slide, do you find the circuit blown after you open the slide? Or, do the lights go out while you're just sitting there while they're on?
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
breaker
