09-07-2023, 09:30 PM
#21
I will. Thank you.
09-08-2023, 08:53 PM
#22
Theresa, did you get a chance to check the fuses? If so, what is the verdict?
09-09-2023, 06:49 AM
#23
Retired Georgia Rally
Originally Posted by Theresa2
There’s currently no power going to the fuse box from the battery when checked with a voltage meter but I will check the reverse polarity fuses with an ohm meter to see if the fuse is blown. But I don’t see how, if they are blown, that would prevent power from getting from the battery to the fuse box.
Check at fuse box there may be a fuse in line and it usually is enclosed so hard to find. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-09-2023, 08:00 AM
#24
Yes, I checked the two 40amp and they are good.
09-09-2023, 08:30 AM
#25
how far away is the dealer ....
if close to home go for a visit and ask them to do another walk through ... they could use another trailer on their lot
OR you drag your trailer back to them
make a list of stuff you have questions about.
Tarpon Springs FL
2022 Salem 24RLXL
09-09-2023, 09:02 AM
#26
I am going to take my camper back to my dealer which is one hour away. They don’t have another on their lot exactly like mine. I have a list started of items that need to be addressed. I’m planning on leaving the camper there for a week to give them time to fix the problems. I will also ask for another walk through with a seasoned tech. Now that I’ve had time to explore my camper I know what questions to ask them.
09-09-2023, 09:19 AM
#27
That’s what I’m thinking too. I’m going to have the dealer check for an inline fuse. I don’t know where to begin looking. They installed the battery.
09-09-2023, 09:20 AM
#28
another good source is your campground manager or hosts
don't be shy of asking them for help if you get to a campground and can't get something to work.
Manufacturers often use the same components and are just different because of their layout... experienced campers can sometimes easily find/workout where your stuff is and how to troubleshoot.
Tarpon Springs FL
2022 Salem 24RLXL
09-09-2023, 10:33 AM
#29
That’s good to know. Thank you.
09-09-2023, 10:47 AM
#30
I’m planning on leaving the camper there for a week to give them time to fix the problems. .
A WEEK!
Please verify with them if that is possible. Some dealers take a week to diagnose a problem, then several weeks to get the problems fixed. Sometimes it takes them months to get parts, so make certain you have a clear understanding of what to expect.
We are no longer under warranty, but waiting on parts took 6 weeks. We were able to take ours home and bring it back for a one day installation for parts, but that took some negotiation with partial payment in advance.
2015 Dynamax REV 24TB class C
09-10-2023, 07:22 PM
#31
Follow your positive battery cable from the battery on back. If you run into one of these, look for a tiny black reset button. Press it & everything should come back on.
2014 Prime Time Sanibel 3250
09-10-2023, 07:29 PM
#32
Hard to find
It will likely be on the bottom side of the frame, below the batteries or propane bottles, or just under the trailer. You may have to lie on your back on the ground to find it. Just follow the positive battery cable, as stated.
The button is tiny, and you must depress it until it clicks.
Larry
09-10-2023, 07:40 PM
#33
X2
09-10-2023, 07:43 PM
#34
I just find it hard to believe that the OP's 2023 Tracer doesn't have a factory battery disconnect switch. My 2016 TracerAir had one.
Maybe if it was from their stick and tin Avenger line.
09-11-2023, 05:14 AM
#35
On my 2018 255RB the battery disconnect switch is located in the water connection compartment.
09-11-2023, 06:26 AM
#36
Good luck on having items fixed in a week. It may take them at least 3 weeks or more just to get to looking at it then who knows how much longer it will take to fix. Lot of stories on here folks taking in for warranty work and getting back camper any where from a month or longer. Just hope you got a good dealer. Later RJD
Days camped 2019 62
09-11-2023, 04:17 PM
#37
my 2022 Tracer 24dbs disconnect is in the convenience center door the big red key. It's not exact same model but weird you don't have one visible.
2022 Primetime Tracer 24DBS
2013 f150 2WD 5.0 OEM tow package
EQUALIZER 4 WDH
09-11-2023, 06:22 PM
#38
Originally Posted by Reverse_snowbird
A WEEK!
I will speak with my dealer about the timing. Thanks for the heads up.
