Old 09-04-2023, 10:31 PM   #1
Can’t locate battery disconnect in Prime Time Tracer
My new battery is fully charged but nothing turns on in my 2023 Prime Time Tracer 200bhles. I assume it must have a battery disconnect engaged but I can’t locate it. Can anyone please tell me where it is? I have looked everywhere.
Theresa2 is offline   Reply With Quote
Old 09-04-2023, 10:44 PM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Check under the tongue by the propane tanks that seems to be a favorite place for the Mfg to place them. let the forum know what you find.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-04-2023, 10:45 PM   #3
bikendan's Avatar
Your dealer didn't show you it, during the PDI/walk-through?
I'm guessing in the driver's side front compartment. Probably a pull/push switch, on the panel where you do your water/tv hookups.
Old 09-04-2023, 11:14 PM   #4
Scoundrel
HangDiver's Avatar
Not sure if yours is the same, but here's this:
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 09-04-2023, 11:55 PM   #5
bikendan's Avatar
Yep, that's how my TracerAir's disconnect switch is like, only it's on the upper left side.
Old 09-07-2023, 05:17 PM   #6
There’s no battery disconnect under the tongue or in the front compartment. The ohm meter says the battery is fully charged but no power is getting to the fuse box.
Old 09-07-2023, 05:18 PM   #7
No, not the same. I don’t have that panel in mine.
Old 09-07-2023, 05:24 PM   #8
The guy that did my walkthrough got fired the next day. Apparently he wasn’t doing a good job for anyone including me. Unfortunately. No, the disconnect isn’t under the tongue, or in the front compartment or near any other controls. There’s no power from the battery getting to the fuse box. Maybe it’s a wiring issue and there isn’t actually a battery disconnect on my camper?
Old 09-07-2023, 05:27 PM   #9
Anything is possible.
Try calling your dealer to see if they can tell you where it is. If all else fails, you might need to take it in.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-07-2023, 05:46 PM   #10
I’ve called my dear. They emailed me saying it might be in the front compartment. I had already told them it wasn’t. I tried calling them back, had to leave a message but they haven’t gotten back to me yet. I hate to have to take it all the way back there but I feel like I have no choice. It’s brand new so they need to figure this out. Very frustrating though.
Old 09-07-2023, 06:20 PM   #11
Your other alternative is a mobile rv technician. You can call FR (or perhaps your dealer) to get prior approval. You many have to pay in advance and get reimbursed.
Old 09-07-2023, 06:47 PM   #12
Does everything work when connected to shore power?
Capacitor is offline   Reply With Quote
Old 09-07-2023, 07:39 PM   #13
bikendan's Avatar
Moved thread from the Forest River Lifestyle sub-forum to the PrimeTime sub-forum since the OP is asking for model-specific information and not anything about Lifestyle.
Old 09-07-2023, 08:01 PM   #14
Yes, everything worked at the dealership when it was plugged in.
Old 09-07-2023, 08:10 PM   #15
Chuck_S's Avatar
I assume you mean volt meter and the voltage is 12.6v or higher.
The battery can't charge when disconnected.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 09-07-2023, 08:35 PM   #16
Yes, I mean a volt meter. The battery is showing 12.6v.
The battery is new. The dealer charged it before installing it.
Old 09-07-2023, 08:36 PM   #17
If everything works on shore power, check the reverse polarity fuses at the power panel.
Old 09-07-2023, 08:49 PM   #18
There’s currently no power going to the fuse box from the battery when checked with a voltage meter but I will check the reverse polarity fuses with an ohm meter to see if the fuse is blown. But I don’t see how, if they are blown, that would prevent power from getting from the battery to the fuse box.
Old 09-07-2023, 09:12 PM   #19
Duplicate
Old 09-07-2023, 09:15 PM   #20
It does, check them with a meter.
battery, battery disconnect, cat, prime time, tracer
