Has anyone had problems with their axles? This is the second time that the outer bearing broke apart and the hub fell off the axle! The bearing was greased.
I have a 2013 260 RLD, with 4400# Dexter axles, I have not had any problems with my axles. Suspension is a different matter and I have upgraded that so my tires don't rub the bottom of the trailer any longer.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
I have a 2012 290RLT. This happened to me once in March 2015. Camper was 3 years old. Passenger side rear wheel. I had to replace the axel and hub.
2012 Crusader 290RLT 2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
I have the 2013 290RLT and have both bearings fail on just 1 wheel. My bearings are always well greased. The wheel on the refrigerator/sofa side. There might be too much weight on that side. The axles on that model just barely meet the GVWR of the trailer in my opinion.
Do you know what size your axles are? That's the same side our problem was on. We did find out that the hub that was put on the first time it failed was not a heavy duty hub and the bearings were wrong.
