Old 06-05-2017, 08:23 AM   #141
5er_tom's Avatar
2nd best upgrade I made. Disk brakes is #1.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 06-05-2017, 09:58 AM   #142
I have seriously considered it. I know the drum brakes suck. I'm only at 10,500 lbs... and my 3/4-ton stops it pretty good. I know I would benefit from disk, but it isn't a priority right now. I hate to keep sinking money into it.
325BH is offline   Reply With Quote
Old 06-05-2017, 10:26 AM   #143
Commercial Member
Originally Posted by CaptnJohn View Post
I ran a set of Trailer King about 5K miles on my last 5er until I returned home to my tire dealer. I put Carlisle on them then and had 42 miles on the ones sold to the tire dealer when I put Carlisle on the current 5er.
I agree often the user is a contributor. I also believe the factory just puts them on and sends them with the transporter under inflated at high speeds to begin their life at a disadvantage. My load range E arrived at the dealer with 66 - 70 psi instead of 80. Over 1000 miles under inflated and at high speed caused me to have no confidence in them.
While running 80 psi CIP all the time is desirable the one good thing is the TT was empty so tires were probably not overloaded. Of course the delivery driver also almost certainly exceeded the max speed rating of the ST tires of 65 mph. I observed this when headed West in IL when about 20 TT just flew passed me when I had my cruse set at 63.
Neither the RV company or delivery service cares as they will just wash their hands of their product when you drive off the dealer lot.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Next in Mar 2021 in Perry, GA
Tireman9 is offline   Reply With Quote
Old 06-05-2017, 11:29 AM   #144
Airdale's Avatar
Tire industry standards are quite consistent when it comes to replacements.
Here is what Cooper publishes about replacements;
"If you are replacing the original size tires with tires of a different size, the replacement tires must have a load carrying capacity and inflation pressure capability equal to or greater than the original equipment tires."
Vehicle owner manuals have similar statements about replacements. This is a typical statement from a RV trailer's owner's manual;
"To maintain tire safety, purchase new tires that are the same size as the vehicle’s original tires or another size recommended by the manufacturer."
This is a quote from a NHTSA interpretation;
"Industry standards generally form the basis for demonstrating product safety and quality before courts, regulators, retailers, consumers and others."
Cooper Tire & Rubber Company - Proper Loading
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 06-29-2017, 04:24 PM   #145
GeoArm's Avatar
Finally fixed my Duel Side Blow Outs
Took about 6 weeks to get the J-Wrap and Fenders Skirts, decals. About 3 days work but worth it
ID:	143132   Click image for larger version
ID:	143133   Click image for larger version
ID:	143134   Click image for larger version
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 07-08-2017, 06:23 AM   #146
Can someone tell me specifically what tires are blowing out. I asked my dealer and they stated they knew nothing about bad ties. Thanks
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 07-08-2017, 06:30 AM   #147
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
ANY tire can blow out, especially if it loses air (nail, screw, etc.) and overheats while going down the road.
Some or more prone to blow-outs, others less likely, but the only true answer to "can someone tell me specifically what tires are blowing out" is ANY brand, ANY style...unless you find a solid rubber tire.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 - 2019: 955 ~ Nights Camping 2020: 5 (Slowed a bit due to wife's knee replacement and then COVID-19)
rjshiflet is offline   Reply With Quote
Old 07-08-2017, 06:36 AM   #148
The Tow Max tires ones that Prime Time puts on their units, they are 100% garbage. Some have had a bit luck others horror stories. I got bit in the rear end, our new unit a 2016 Prime Time Crusader came with the Tow Max's tires had little mileage, looked new in every way until it just let go. Theirs a allot of lawsuits in process regarding the Tow Max tires that alone should send up red warning signs.
Some have afforded lengthy explanations regarding tire pressure, weight, and on and on, the bottom line without the hoopla they are a low-quality tire so if you take a risk with them it is what it is. I for one removed all of them even the spare tire.
If I was buying today I would negotiate that all five tires are removed & replaced would never roll off the lot with Tow Max tires any RV knowing what I know now.
esmoglo is offline   Reply With Quote
Old 07-08-2017, 06:40 AM   #149
Thanks I appreciate the information.
2017 Sanibel 3601
Old 07-08-2017, 06:48 AM   #150
I put on Maxxies M8008's on our rig it bounces allot less now it's noteabebly an improved ride while towing. Sitting outside now took a snap of the Maxxies as I sit here drinking coffee enjoying the morning breeze on a 30 day vacation with the Crusader.
ID:	143950   Click image for larger version
Old 07-08-2017, 07:23 AM   #151
chesbass
They know they just don't want to talk about it. In most cases and in my experience it has been good year marathons
chesba88 is offline   Reply With Quote
Old 07-08-2017, 08:57 AM   #152
Bikersarge's Avatar
We have a Tire minder that monitors heat temp and tire pressure, they are pricey but worth the peace of mind. When we purchased our 5th whl in may we had the tires removed and sailun G rated 14 plys put on, Camping world in Hamburg NY gave it to me with no Vaseline charging me 25% more along with 50.00 a tire to mount each tire but we were not pulling our Toy hauler with china bombs.
I think alot of blow-outs are due to lack of correct tire pressure and speeding down the interstate which heats them up, especially those E rated on some brands I run about 63-65 mph...the temps on my tires run cool. Also I see alot of new Rigs with those bubbly no strength side walls which my ride better but very poorly designed.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 07-08-2017, 11:04 AM   #153
They are easy to identify. They have "ST" on the sidewall.
Old 07-08-2017, 11:35 AM   #154
Old 07-08-2017, 02:08 PM   #155
CaptnJohn's Avatar
The ONLY tire I had blow in 54 years driving and 43 years pulling had an LT on it. LT by GY. I'll stick with GOOD ST tires and take care of them. Think Sailun, Carlisle, Maxxis. Never buy anything that says Goodyear!
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 07-08-2017, 02:51 PM   #156
m35a2's Avatar
If you look at the numerous tire/blowout threads here, a common theme in the stories and pictures is that tpms was used, tires were at pressure, and tread separation always occurs. Even on the tires people caught before the tire blew.
I think it's a crap shoot, and you lessen your odds by maintaining pressure, monitoring temps, etc.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 07-08-2017, 03:07 PM   #157
Just looked and my tires are the GY Marathons ST. I guess they are doomed to fail. What does GY have to say about this issue?
2017 Sanibel 3601
Old 07-08-2017, 03:43 PM   #158
CaptnJohn's Avatar
GY says buy the new Endurance and test them for us at your expense.
Old 07-09-2017, 06:30 AM   #159
Sad that they don't stand behind their products
2017 Sanibel 3601
Old 07-10-2017, 09:59 PM   #160
dcheatwood's Avatar
I've had 3 explosive blowouts and one tread separation. ALL were Trail Express tires, originals on two different fifth wheels.
2018 Forester 3011 DS
tire, crusader
