03-13-2017, 10:42 AM
Crusaders What Fridge do they come with
Mine is a Norcold which I prefer but the outside vents say dometic.
I wonder if they had to replace anything or they just swapped the outside vent cover?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
03-13-2017, 10:49 AM
mine is a norcold
2006 F-250 CCSB 4x4 6.0 Powerstroke
Air Lift 5k bags w/ onboard compressor
2022 Keystone Raptor 351
B&W Companion
03-13-2017, 10:57 AM
Yeah sonis my 2013 but covers outside on slide are Dometic? Strange but I think he had the big covers in the norcold ones and kept them
Originally Posted by Brendon37
mine is a norcold
Your Hot Eater Heater is a DSI Atwood 6 gal correct?
03-13-2017, 11:12 AM
yes sir mine is the atwood 6 gal
B&W Companion
03-13-2017, 11:15 AM
ill have to double check what my outside vents say when i get home from work and ill let you know
B&W Companion
03-13-2017, 12:10 PM
Ok thanks, not sure but I am not about to spend $80 just to replace them?
I was buying the vent screens for bugs and that is what threw me off, Fridge is Norcold but outside covers are Dometic
03-13-2017, 12:58 PM
Prime Time Manf. Crusader 270RET 2012
Ford F150 5.4L B&W Companion Hitch
updated to Andersen Aluminum Ultimate Hitch 2017
03-13-2017, 01:00 PM
03-13-2017, 02:41 PM
Mine came with the cheap Norcold, no way to switch from elec to gas other than pulling the vent and unplugging it in the back to force it on gas
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
03-13-2017, 03:19 PM
Yup I have a norcold also.
03-13-2017, 07:58 PM
I have the 2023 Crusader 295 and ours auto switched from electric to gas? We drove 6 hours and it was freezing in there when we got home until I turned it off and **** the propane.
My 2012 Shasta had Norcold which switched as well, I hated the Dometic in my Rockwood Roo very noisy
03-14-2017, 08:55 AM
My 320rlt has Dometic.
03-14-2017, 09:04 AM
i checked mine last night and couldnt find a name on the fridge cover. but it looks like all the other covers on the 2017 crusaders
B&W Companion
03-14-2017, 03:21 PM
Norcold refrigerator. It auto switches between gas and 120vac. There is no hose hanging out of the outside covers like the Dometics (I actually prefer that drain method, but didn't have a choice).
For the outdoor vents, I simply bought some aluminum window screening from Lowes. Took off the outside covers and measured the area. Cut the screen down to size. Placed the screen over the area and then put the covers back on over them. Push it a little harder than normal and the little "twist locks" will push through the screen and lock in place. Cheap and easy. You can't see it from outside, so who cares if it looks any different than the other mud dauber covers.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
03-14-2017, 03:25 PM
Wow, wicked1, you have a 2023 model?!?! Back to future!
Ben and Doreen
03-20-2017, 06:39 PM
Mine is a Dometic.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
03-20-2017, 06:49 PM
Ours is Dometic
03-20-2017, 07:03 PM
Not sure why but mine is a Norcold which I like better having had both models but ext access panels say Dometic? Maybe they replaced one or the other as mine is a 2013
03-20-2017, 07:17 PM
Ours is a 2014 built in May 2013 ...is there a manual for your fridge? Maybe it was replaced for some reason if you are not original owner
