Old 10-31-2020, 09:07 AM   #1
Installing larger windows in bedroom of 5th wheel
my 2017 Primetime crusader lite 5th wheel came with some of the smallest windows ever in the bedroom.
I would like to order new larger windows to replace the smaller windows
The question I have is, has anyone done this before, and if so what is the difficulty level.
2nd question, will it compromise structural integrity of the 5th wheel in any way?
regards,
Mike
mbradford99 is offline   Reply With Quote
Old 10-31-2020, 07:05 PM   #2
rracer5's Avatar
regards,
Mike
IMHO, it may. The sidewalls are constructed out of a welded aluminum frame with laminated, insulated & bonded interior & exterior walls (see your factory sticker near the entry door). If you start cutting into the walls you may run into aluminum studs and crossmembers which if cut out, would weaken the rigidity of the walls and possibly lead to delamination due to wall flex.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
5th wheel, bed, bedroom, roo, wheel, window
