X2 on the Torklift steps. Their "uprising" version that competes with the drawbridge style allow you to access your camper as long as you can open the door enough to slip in, you can climb over them. They are fully deploy-able as long as you can open the door to just under 90 degrees.
I have a set of the older under-mount steps and REALLY like them. Made of heavy gauge aluminum and stainless steel, they don't rust.
For both versions, you can pick how many steps you want and add or remove if you change your mind. Both have adjustable legs the sit on the ground when deployed, so no bounce when someone uses them.
They are a bit on the pricey side, but in my opinion, worth the cost.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
