New guy to site! So thanks in advance. 2019 avenger 26bbs slide out question.
Ok so thanks again! Well I have a 2019 avenger ati 26bbs, and when I put slide out out I hear some slight grinding, when retracting it is lubed with dry spray lube from dealer, looks good a the gear and track that are visual under the slide out, so could it be coming from the electric motor in the floor was think maybe a bad gear at motor. And also does anyone know what brand type slide outs are used in these. This week end I will pull the small cover off under neath and inspect but just wanted to know what to look for. Thanks again
