Old 08-12-2013, 09:10 PM   #21
Platokidd's Avatar
Originally Posted by KAB449 View Post
I am having problems with this system also. When I took it in for warranty work I asked them to look at the tracks because at least 2 of them were flaking off metal pieces and the wear marks showed that the driving gear and the driven gear were not meshing properly. Dealer said the adjustment was not correct and will have to replace the tracks and make sure they are in proper adjustment. I suggest you closely inspect the tracks for this problem.
I noticed 1 gear tooth on each side of the top outer edge of my closet slide has a damaged or flaking off metal pieces on the tracks. Geeeesssh I will just add it to the list
But it seems to work great, I realy like the Schwintek slide system.
Thanks for the tip
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
