Originally Posted by Hoakieman
I'm at my wit's end, can't get a wiring diagram for my Crusdader Lite. Primetime doesn't provide them and dealers don't want to sell them.
I discovered I have an open ground after the first recepticle, four recepticles are affected the two back by the recliners on either side of the end table and the two in the slide out behind and below the TV entertainment center. They all show 115v +/- between the Black and ground, and a varting voltage accross the black and white, but not enough to operate anything. My tester shows they are wired correctly (two yellows). Someone mentioned that the ground and common might be revewrsed some where but I can't find it. What I have done is replacd each of the junk outletswith standard home ones set in Old Work boxes to be sure they are all wired correctly. They are. There must be a junction box somewhere but without a wiring diagram I just have to start ripping into the underside to find the wires...don't want to do that. Anyone have any advice? The dealer wants me to bring it in...I can fix it if I know where the wires are.
Over the years in my career I found getting wiring diagrams and such to only be difficult, not impossible.
If they exist and a Dealer actually has what you need go to a lower level individual in the shop that has access. Often a trade can be made often in the form of a "bottle of their favorite" for a zerox copy.
Kind of a "Radar O'Reilly trade".[emoji41]
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
