Old 09-17-2013, 03:58 PM   #101
Very interesting! As you know, that material can be pretty brittle. Are the guides not making contact with the "formica" when the slides are fully extended or fully retracted? If that can be done, I think it would reduce the likelihood of cracking the material during normal use stresses.
Old 09-17-2013, 05:59 PM   #102
zs325RES's Avatar
Yes the laminate is brittle but hard as needed.
The guide is not in contact with the laminate only when the room is all the way out. I butted the strips right up to the guide when the room was out before fastening. I did try prying the floor up from the guide so I could get the strips under there but you have to lift the whole room to do so. I believe the 'chamfer' I put on the leading edge worked well.
I've got two outings planned in the next two weeks so it will get cycled several times.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 09-17-2013, 06:19 PM   #103
Platokidd's Avatar
Z
Looks interesting... I cant see the staples. Are you concerned about water getting threw the staples holes? If you do another one please take more pics of the process for us.
nice job
Carl
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 09-17-2013, 09:54 PM   #104
Originally Posted by RV Guy View Post
I wanted to address some aspects of this situation as it certainly is generating a lot of attention.
Essentially, there are three different types of slide floors that we use at Prime Time and all of them are being lumped into the same conversation on this thread.
1) Darco wrapped -.....
2) Pre-Engineered Board - ....
3) Laminated - .....
The wearing of the black top coat on the FloorBrace seems to be the biggest issue outside of the fraying tape. We don't have any conclusive answers on this yet. Samples have been sent to the manufacturer and they are actually flying in to see us this week from Seattle for more conversations. We will keep you updated on what we find.
RV Guy,
You mentioned above 4 weeks ago hat they were working on a solution for this. I have a 2013 Tracer 2670BHS. As far as I can tell , it has the FoorBrace because the rollers have tore the Darco tape, and the edges of the floor board are exposed and white in color.
Either way, it would appear that the edges of the floor board need to be sealed around the bottom edge of the slide to prevent water from wicking under the slide and under the black outer material or into the screw holes along the edge.
Very curious if I contact my dealer if they will get any kind of official fix from Prime Time?
brianjames is offline   Reply With Quote
Old 09-18-2013, 05:55 AM   #105
Platokidd's Avatar
Originally Posted by brianjames View Post
RV Guy,
I had a 2013 tracer 2670bhs and mine did not have the "floorbrace" product on it(laminated floor / darco fabric). It was wood and a black paint on it. Cant remember what the ends looked like, think it was tape but not sure.
Either way best to get it addressed by your dealer. Have them seal all the exposed areas and screw heads. Other wise you will have problems.
Carl
Seasonal
Old 09-18-2013, 01:47 PM   #106
New 290RLT Touring Edition Slide Wear
Ordered a new 2014 Crusader prior to knowing about the underside wearing issue. Took delivery two weeks ago. First thing to check was the underside of the slide outs. Not sure how many times the slides were opened and closed at the factory but from the couple of times they were opened at the dealer, they are already tearing. There is also a screw head that was not set right at the factory. As the slide retracts, the screw head makes contact with the floor and has put about a 10" tear in the floor. And I have not even used the trailer yet. Dealer said it would be covered under warranty but was unaware about the underside wearing. Still hoping to enjoy the trailer as both myself and my wife really like it. Just hoping this isn't the beginning of a long list of issues.
rgendreau is offline   Reply With Quote
Old 09-18-2013, 02:10 PM   #107
another_newfie's Avatar
rgendreau where is that screw head? I suspect mine has the exact same issue.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 09-18-2013, 02:39 PM   #108
Platokidd's Avatar
rgendreau
Welcome to the forum! sorry to hear about your units problems.
They all can have problems that have to be worked out or fixed.
Prime time makes a good unit.
But the slide wear is a problem that has to be delt with!!
Bet the 2015 or 2016 dont have this problem,
carl
Seasonal
Old 09-18-2013, 03:45 PM   #109
I had the same problem with the screws that hold down the heat registers making contact with the underside of the slide when it was in, I countersunk the register and changed the screws.
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2019-41/2020-lots planned
2017-51/2018-55
2015-57/2016-52
keepaeyeonit is offline   Reply With Quote
Old 09-18-2013, 04:03 PM   #110
Screw head
On mine, the screw head is located towards the edge of the slide that is almost inside the camper right on the corner. I found it when I was moving the seals around to find out what the fabric on the slide was sliding on. The screw does not make contact initially but on the roughly last 8-10" of movement in, the slide seems to "dive down" towards the floor. I put a piece of rug under the slide the last few times I opened and closed the slide. This prevents the screw head from contacting the floor. The screw head is buried just enough in the seals area that I cannot get a screwdriver to try and tighten or remove the screw.
Old 09-19-2013, 02:53 PM   #111
GeoArm's Avatar
You will enjoy the crusader, we do
I only have on side of one slide ripping and showing wood. Other than that all good! Prime time fixed any little issue with no hassle or problem for me. But I am dropping the unit off next week for the slide wear. Keep ya posted
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 09-21-2013, 11:36 AM   #112
Platokidd's Avatar
Just curious, anybody had there slide issue fix yet ???
Seasonal
Old 09-25-2013, 08:44 PM   #113
Sgt. Schultz's Avatar
Still in the works I guess
PT Avenger 33BHS-TE
2020 f-250
Sgt. Schultz is offline   Reply With Quote
Old 09-26-2013, 08:48 PM   #114
man, I was looking hard at the crusader 335bhs, but this slide thing doesnt sound good at all. I hope they make it right for you all
gtsum2 is offline   Reply With Quote
Old 09-26-2013, 09:26 PM   #115
William
WEMig's Avatar
I have a Crusader. No issues with ours.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 09-27-2013, 08:00 AM   #116
Absolutely love our Crusader and just traded up for a new Crusader 325 RES.
Very few problems. Great service from Ansley RV.in PA.
grayfox is offline   Reply With Quote
Old 09-27-2013, 08:54 AM   #117
Our rig is going to the dealer next week. One of the issues will be the slide wear. Although in my case the wear is likely caused by a screwhead. We will see.
Spent another night in our Prime Time product last night and I am happier each night that we use it that we chose Prime Time! Their customer service is simply outstanding as well.
1 Fantastic DW
1 Amazing DD
Old 09-27-2013, 09:07 AM   #118
zs325RES's Avatar
I'm pretty pleased with my mod.
It's worked great so far. We're using our 325RES now in Pentwater, MI
Absolutely beautiful weather in the most beautiful place, during the best time of year to glamp in the season.
I'll probably do the same to the kitchen slide as well.
Curt Q20
Old 10-02-2013, 09:17 AM   #119
irishrv's Avatar
Mine is going in for slide wear. Replace the fabric and adjust is what PT and dealer have said.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 10-02-2013, 09:29 AM   #120
DAISY BOYKIN's Avatar
Maybe Prime time------------
Maybe Crusader should look at the Rockwood fifth wheels slide out construction. Mine has a hard plastic covering the complete bottom on the slide out and a hard plastic material covering the part that touches the rollers when it is moving in and out.
Wrong heading! Not Prime Time----
Just saying
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
slide, slide out
