Old 11-19-2020, 08:16 AM   #1
mitsured's Avatar
Tracer Air 250 Slide scraping floor.
Hello All,
First I'd like to say great Forum! I purchased my first "new to me" travel trailer on Oct 31st and picked it up a week later. It had a few minor issues wiring, adjustments etc, and I found answer to all but one of the issues on this site! So Thank you!
The one last issue I have is with the slide/kitchen cabinet.
When the slide is almost all the way in the front right bottom corner of the kitchen cabinet scrapes the floor.
This looks like a fairly recent issue as the piece of flooring that was pulled up was still fully intact when I first looked at the trailer. From then until now the slide has gone in/out maybe 10 times and the piece of flooring is showing wear.
At the dealer the stabilizers were NOT down and the trailer was not level.
At my home I have only put the slide in/out with the trailer level, wheels chocked, and stabilizers down.
Kitchen cabinets seem in good shape, no water damage, seem level, nothing rolls around, can't see any screws loose inside the cabinet.
I've included some pictures though can take more from any angle you'd like.
It is a Schwintec slide.
Anyone have any ideas what I need to check next to resolve this issue?
Name:	Floor Scrape from above kitchen on right.jpg
ID:	243319   Click image for larger version
Name:	Floor Scrape from above standing by Dinette.jpg
ID:	243320   Click image for larger version
Name:	Floor Scrape from Dinette.jpg
ID:	243321   Click image for larger version
Name:	Floor Scrape bottom corner of kitchen cabinet that hits floors.jpg
mitsured is offline   Reply With Quote
Old 11-19-2020, 08:40 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. You pic to me does not look like the cabinet is the problem but rather maybe there is something under the vinyl that has caused the ware mark. I would get it in to the dealer and have them fix the problem.
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-19-2020, 11:41 AM   #3
rracer5's Avatar
Originally Posted by mitsured View Post
Hello All,
Get yourself a set of Slideout Slickers from AP Products #013-410051
https://www.amazon.com/AP-Products-0...5803928&sr=8-7
We had the same problem because our kitchen slide is so heavy it kept "going out of adjustment".
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-19-2020, 12:07 PM   #4
mitsured's Avatar
Hello,
I was looking at this though I was worried the additional height would cause the face plate of the cabinets to be pulled away as the slide was going out, or at least the Formica fronts.
Is yours also caused by wood cabinets hitting the floor once the slide is pulled all the way in?
Old 11-19-2020, 12:24 PM   #5
mitsured's Avatar
It was a 2014 as-is purchase so the repair are on me.
The floor is nice and flat, no bowing etc I took a long level laid it across the floor and ran a light behind it. Was level all the way from the dinette to the kitchen cabinet.
Seems like the slide is leaning in/down meaning the inside of the slide is lower than the outside.
The counter is level when the slide is out I'll have to also check when it is in to see if it is still level.
Old 11-19-2020, 03:04 PM   #6
One corner of our slide does this. We took a square of some scrap carpet we had laying around and turned it upside down. Now we watch the slide come in and just before the corner starts to run we place the carpet square down on the vynal flooring fuzzy side down. Then bring the slide the rest of the way in. Stops the slide corner from marring the floor. Works for us.
shadows4 is offline   Reply With Quote
Old 11-19-2020, 04:16 PM   #7
mitsured's Avatar
Thank you! This sounds like a winner. I have some carpet squares laying around that I could use.
How long have you been doing this?
Seen any signs it may be causing issues somewhere else?
Old 11-19-2020, 05:25 PM   #8
Check to see there is not a screw sticking out bottom of cabinet.
Harkerr is offline   Reply With Quote
Old 11-19-2020, 07:41 PM   #9
mitsured's Avatar
The bottom is smooth, well as smooth as the end of particle board gets.
Old 11-19-2020, 09:29 PM   #10
I have a 2017 forester MBS with a full wall slide. A short time after I got it I noticed two depressions just starting in the flooring in similar positions as your pictures show. It seems the only thing that holds the slide up on mine were two small (2Ēx5Ē) shoes that the slide rides on as it comes in. A third in the bed room but out of sight. The shoes only had a piece of carpet stapled on the bottoms for the slide to ride on. They are actually up off the floor when the slide is out. Went to Walmart and found 3x5 felt pads with peel back adhesives. Stuck them to the shoes and have had no more issues. Been a while but I think I may have used two on each. Tried with small furniture movers first just to test slide. Also same slide system you have. If your floor is too rough, may be too late for anything but the sliders as already shown. They are also a great idea, good luck.
bowler is offline   Reply With Quote
Old 11-19-2020, 10:26 PM   #11
mitsured's Avatar
Smile
Hi bowler,
Thank you for the response. It sounds like you have a great fix. Like you stated the corners of my kitchen cabinet are also a good inch + off the floor when the slide is out. I am not sure what you mean by shoes. I've noticed there are rollers under my slide, are the shoes on top of the rollers?
We'd like to replace the floors in the future though we'd like to make sure we're not going to tear a hole in them.
if at all possible would you be able to post some pictures of where you placed the felt pads?
Old 11-20-2020, 09:13 AM   #12
rracer5's Avatar
Hello,
No. Ours was caused by the weight of the refrigerator on that corner of the slide. It was the floor of the slide scraping the main floor as it went in & out.
Looks like bowler has a great idea. One of those small felt furniture sliders glued up under that leading edge might work well.
2014 Sanibel 3250
Old 11-20-2020, 10:47 PM   #13
Shoes are small blocks on inside slide bottom that were made to slide on floor with thin carpet. It just wasnít enough cushion when the slide came in. My rollers are mounted on outside edge of floor. The slide is made to slide directly on the floor surface. I had slight depressions just starting on floor. Cheap fix so far and two years old. Will try to get some pictures at you.
Old 12-02-2020, 10:08 PM   #14
mitsured's Avatar
Sounds like your slide may function a bit different than mine though I dont see why the felt pads would work.
The issue is friction and the pads should decrease the friction.
Old 12-21-2020, 08:14 AM   #15
mitsured's Avatar
I ended up trimming down a furniture pad that would normally be used for couch legs. I stuck it on the bottom of the kitchen cabinet and so far so good. Thank you for all the input.
I'm still a bit concerned as to why it would hit the floor while the slide is in though about 2 inches off the floor when the slide is out. I'll just keep an eye on it and it gets any worse I'll be back for more advice!
Old 12-23-2020, 11:50 AM   #16
My Georgetown is doing the same thing. Extend your slide and look underneath. Are the rollers digging into the bottom of the slide? Thatís what is happening to mine. There is another good post on this forum if that is causing marks on your floor.
Sonic Blue is offline   Reply With Quote
Old 12-23-2020, 09:49 PM   #17
mitsured's Avatar
Thanks for the info I'll take a look at mine in the morning.
You wouldn't happen to know title of the other post on this forum?
Old 12-24-2020, 11:14 PM   #18
Floor Delamination
The post is by Milman and I think the title is something like slide delamination or slide exfoliation. It is a very recent thread.
Old 12-25-2020, 12:01 AM   #19
Link to Slide Out Thread
Here is a link to the thread:
https://www.forestriverforums.com/fo...-new-post.html
250, adjustment, floor, repair, slide, slideout, tracer
