Originally Posted by rracer5
This one has me stumped!...
You and me both.
It does have the covered under belly along with a lot of expansion foam around the sewer outlet. They also ran the gas line under the under belly so I'd to find a way to drop that as well.
I was able to take out a couple screws and pull the under belly down a few inches which is how I could tell where the stream of water was coming.
I also think I've determined where the water pump is located. It sounds as though it's behind a panel within the back right storage compartment below the bunk beds. It would also makes sense as that would be right in front of the hot water heater.
Though it doesn't help to explain why the water is coming down from a location 6 to 8 ft in front and a foot higher than where I think the water pump is located.
The bath is also in the rear so the pump is behind the bathroom through the leak is in front of the bathroom.
I'm thinking it's got to be a valve though still doesn't make sense seeing it is only 1 faucet.
Right now the plan is not to use the bathroom sink if we're using the pump.
