Old 02-19-2021, 12:04 PM   #1
Transporting Kayak
Thinking of just strapping my kayak to my roof ladder, Seems simple, but I have not seen it done. Any reason not to? Too much stress on the screws holding the ladder?
2020 Prime Time Crusader 297RSK
2017 Ram 2500 Diesel
bgolfb4 is offline   Reply With Quote
Old 02-19-2021, 12:31 PM   #2
Thumbs up
Get a couple Pool Noodles to go on your ladder and you should be good. I'm looking at strapping on two so I'll have to do something different.
The Ladder is built/engineered for several hundred pounds so a 50 lb kayak shouldn't cause a problem.
CrazyOldGuy is offline   Reply With Quote
Old 02-19-2021, 04:00 PM   #3
rracer5's Avatar
You should be good to go but, just check the screws periodically as the bouncing of the extra weight tends to loosen the screws. It happened to me carrying two bikes.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-19-2021, 04:29 PM   #4
Do make sure you don’t stick up higher than the bridges stick down.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
WanderMore is offline   Reply With Quote
Old 05-16-2021, 01:58 PM   #5
Personally, I would not trust the ladder to hold a kayak. If you look at the size of the screws holding the ladder to the back of the rig, you'll see they are fairly small and not necessarily going into anything other than the siding. When you figure the additional stress and load created by the normal jostling of going down the road, that adds quite a bit of strain on the ladder. I would consider adding additional support from the rear bumper to carry more of the load.
Can you imagine what would happen if something came loose while traveling at 50+ mph? The poor guy behind you
CraigJean is offline   Reply With Quote
Old 05-16-2021, 02:50 PM   #6
Yes, I decided against it and purchased a blowup kayak
Old 05-17-2021, 11:13 AM   #7
Funny, that is exactly what I did. I did not want a big rack on my truck for a hard shell and I did not want to hang it on the ladder. I bought a good two person kayak that I can roll up and put in my big tool box and blow it up when I need it.
sport
