Old 07-23-2021, 10:45 AM   #1
Wheel nuts torque pressure.
I bought a 2017 Prime Time Crusader 20 RL and have no documentation for it.
I would like to know to which pressure the wheel nuts should be torqued.
The wheels have 6 studs of about an inch in diameter, and the tires are ST225/75 R15D
2018 F-150, 3.5 echo boost
Your children and grand-children will not remember what you did for them, they will remember what you did WITH THEM.
Quiroule is offline   Reply With Quote
Old 07-23-2021, 11:03 AM   #2
Commercial Member
Google is our friend.
https://www.etrailer.com/question-75604.html
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Next in March 2022 Tuscon AZ
Tireman9 is offline   Reply With Quote
Old 07-23-2021, 11:43 AM   #3
The torque specs for your RV are going to depend on whether you have flange or cone nuts, but I'm guessing you likely have flange nuts based on your wheel size.
Since this is a Forest River product and they usually use Lippert frames, you can find the torque specs in the link below. But first confirm your RV frame manufacturer and consult their website for that information, if it's not a Lippert frame.
https://lci-support-doc.s3.amazonaws...cd_0001812.pdf
I keep a downloaded copy of this and other Lippert documents on my notebook system that I take everywhere, so I always have it while on the road with my RV, just in case.
2020 Forest River Sabre 37FLH
2013 Ford F-350 XL Crew Cab 6.7L Diesel DRW
Tulip, the Wonder-Shepherd
GPs37FLH is offline   Reply With Quote
Old 07-23-2021, 01:40 PM   #4
Thank-you both for help.
I have a Lippert frame with cone nuts.
Have a safe camping trip.
Old 07-24-2021, 10:33 AM   #5
Wheel nut torque
I have a 2013 Crusader with 6 lug nuts and when new there was a tag on the side that said to torgue at 100ft-lbs. The tag has since been removed but when my mobile RV guy does my bearings he always torques at 100ft-lbs. When I get new tires at Schwab they always torque at 100ft-lbs.
2013 Crusader 290RLT
2018 Silverado 2500HD 6.6L Diesel
Crusaderguy is offline   Reply With Quote
Old 07-24-2021, 10:57 AM   #6
Thanks. It makes sense
Old 07-24-2021, 04:32 PM   #7
On my trailer it is 90 - 95. ALO axles. 6,000bls. I always try for 95.
Portagie1968 is offline   Reply With Quote
pressure, wheel
