Old 06-14-2019, 07:37 AM   #41
Brother Les's Avatar
Originally Posted by mike4339 View Post
I haven't had to change a tire yet, but I did buy a cordless impact driver and deep sockets for my truck and 5th wheel in the event that I do have to change a tire..I make sure the battery is fully charged before each trip, and put it in the storage area...much easier to remove the lug nuts, especially if wheel is already off the ground. And since I have a self leveling system, I would use that. I have heard don't jack under frame and axle, but in the event of a flat without the leveling system, I would opt for between the u-bolts.
If you plan on depending on your electric drill, you will come across one or two lug nuts that it will not loosen..... and then what??? have a breaker bar that will fit your deep socket. One more thing to pack, but one more thing that you will cuss about for not having when you need it.
Brother Les
Old 06-14-2019, 08:26 AM   #42
While we're on the subject of safe jacking, and tire changing, let us not forget to retorque the lug nuts, both before the trip, and after the tire change. I carry a cheapy torque wrench just for that purpose. Accurate enough for lug nuts. You won't be singing that Glenn Campbell song, "You picked a fine time to leave me loose wheel".
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 06-14-2019, 09:35 AM   #43
Now that there is funny, I don't care who you are. Wasn't that Kenny Rogers though?
Poison Ivy is offline   Reply With Quote
Old 06-14-2019, 09:47 AM   #44
Originally Posted by CentralMePistol View Post
FYI
I was told by the parts manager at our dealership, so I can't confirm, that the rapid jack won't work if you have the "wide track" axles or however you describe it. Never tried a board ramp. Just a heads up for those that have the "wide track'. I'd hate for you to find it out on the side of the road.
lewisra is offline   Reply With Quote
Old 06-15-2019, 08:21 AM   #45
I think you're right.
2003 Duramax
2017 Crusader 315
Old 06-15-2019, 10:47 AM   #46
Originally Posted by lewisra View Post
FYI
Wondering if anyone can confirm this. I am just about to order one. I'm not sure what qualifies as a wide track axle. I have a Coachmen Freedom Express 248RBS.
2018 Coachmen Freedom Express 248 RBS
2014 Toyota Sequoia
stlsailor is offline   Reply With Quote
Old 06-15-2019, 11:48 AM   #47
I don't know what a wide track is but my hubs are 31 inches center to center and it works for me. In my muddy back yard I had to put a board under it. I have the bigger one of the two.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 06-15-2019, 04:39 PM   #48
I have the wide axels, called EZ Tow they are 41 in apart. It will not work. On our SOB I used my leveling blocks to do the same thing, on this one, no go, not even close to lifting the other axle. You will need a Jack, or AAA RV. I have a Jack if I dont have cell service, but I have done side of the road trailer rocking enough times to not want to do it again.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 06-15-2019, 07:50 PM   #49
Leveling system works great if you have it. If not, I put bottle jack the same place ependydad does. Worked good so far.
Moochie6903 is offline   Reply With Quote
Old 06-15-2019, 10:16 PM   #50
Typical wheelbases are either 33" or 35" for 14" and 15" trailers. Never heard of 31" before.
babock is offline   Reply With Quote
Old 06-15-2019, 10:42 PM   #51
dbledan's Avatar
If you have some 2x6 leveling boards you can notch them half round out to match the axles to hold both axels and triple them up when jacking up. It would lift both wheels and support the weight and the notch would not harm your leveling abilities. This would be cheaper than the alternatives.
dbledan is offline   Reply With Quote
Old 06-16-2019, 07:50 AM   #52
Just fired up the old tape measure and the hubs are still 31" so you can say you've heard of it now.
Jeff
2016 APEX 215rbk
Old 06-16-2019, 09:40 AM   #53
Leveling jacks
So when using the leveling jacks, do you have to disconnect from TV
S.kimbruce is offline   Reply With Quote
Old 06-16-2019, 10:29 AM   #54
glsimms's Avatar
No
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 06-16-2019, 10:35 AM   #55
If you are referring to the corner stabilizer jacks on a TT you do not use them to level, only to stabilize. Which means you put some force on the jacks but you are not adjusting the level(ok, so the TT may move an eighth or quarter of an inch or so). If I am traveling through and can get level enough without unhitching I don't unhitch. Usually do not use stabilizers to save time, but I could and put about the same amount of force on each corner without attempting to change level.
Jeff
2016 APEX 215rbk
Old 06-16-2019, 03:16 PM   #56
My “wide track” is 42”. 15” tires.
tire
