Old 04-10-2019, 02:58 PM   #21
camaraderie's Avatar
John...right...I did not read your further comments...but same end game anyway!
By all means, buy two of the same age and type. If you are using that Viking charger in your picture may I also suggest you get a real charger capable of properly treating and maintaining a pair of quality deep cycle batteries. This would mean a progressive or Iota or similar smart 3-4 stage charger and not the el cheapo pulse high frequency stuff fine for scooters and the like. If you're gonna get two batts...get something in the 50amp range. And don't leave it plugged in unless you need to use it! Good luck!
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 04-10-2019, 05:27 PM   #22
Conventional batteries contain a liquid “electrolyte” which is a mixture of sulfuric acid and water The water evaporates a bit with charging but the sulfuric acid stays in the battery.That's why we just add water when low.Getting the acid on your hands or clothes does not show up right away until the clothes are washed, then we see the holes.
Mark1 is offline   Reply With Quote
Old 04-11-2019, 12:03 AM   #23
Battery leaking
Your battery is bad it is degassing has nothing to do with the charger get yourself a new battery
johnlochbuie is offline   Reply With Quote
Old 04-11-2019, 12:26 AM   #24
LOL...degassing?
babock is offline   Reply With Quote
Old 04-11-2019, 09:38 AM   #25
Denver To Yuma In 90 Days
Originally Posted by babock View Post
LOL...degassing?
That's what I do about an hour after stopping at Taco Bell!
JohnD10 is offline   Reply With Quote
Old 04-11-2019, 02:18 PM   #26
Just as confused as you
Scrapper's Avatar
Your battery is probably suffering from degradation of the casing where the fill holes are and the top cap is sealed at the terminals and side seams. Have seen this many times with batteries brought in for recycling. This is usually a sign of age but have seen some less than a year old due to manufacturing defects.
Richard & Jill
battery, water
