04-20-2011, 06:08 PM
#21
Originally Posted by kjoh75
Forgot to mention that I did buy a Honda 2000i generator ($850 on Black Friday, Northern Hydralics) but never took it out of the box. I was later told that it wouldn't handle the air conditioner in my camper. So I returned it and purchased a larger 3500 watt generator ($300 not Honda). That to is still in the box because I haven't needed it yet. But the down fall is that it's big and loud and weights 150 pounds. Not very convienent to say the least. No where to put it on the camper too (gas fumes not wanted in the pulling SUV, Expedition). I will probably keep it for home use and bit the bullet and buy the Honda 2000i again for camping (who needs air conditioning). Just wish there weren't so expensive.
My opinion is to return that 3500 watt monster and go back and get that 2000i Next year you can get the "companion" 2000i and run anything you want with QUIET 4000 watts.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-20-2011, 06:10 PM
#22
Originally Posted by ken0042
Possibly a dumb question; could you not charge your trailer's battery from the TV using jumper cables?
Not a dumb question at all.
However you will have the same issues pretty much as if you plugged the trailer in to the TV. Not to mention your truck is going to burn WAY more gas than any generator.
04-20-2011, 07:07 PM
#23
I was just thinking it would draw more because at that point the load would be right at the battery; causing the alternator to work pretty hard. I know in the past when I've had a car with a bad alternator we have left the jumper cables on for an hour to charge up the other vehicle's battery; then had enough power to get the dead car home. That's why I was thinking it could charge up the deep cycle battery in just a couple of hours.
What I was thinking of is how people talk about spending $1000-1500 on a generator; if I only dry camp 4 times per year and spend $15 in gas to run the truck for 2 hours; it would take over 16 years for the generator to pay for itself.
Obviously a generator has other advantages like being able to run A/C or a microwave, but for the purposes of plain dry camping, I am just looking for other alternatives.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
04-20-2011, 07:17 PM
#24
Well, a lot depends on what your draw is on the battery. If you pull say an average of 12 amps for 6 hours, you would have to run the truck charging at 12 amps per hour for 6 hours to replace that juice.
If you drew 6 amps from the battery for 6 hours, you would need to run the TV for 3 hours at 12 amps to replace that juice.
most common 12 volt items.
LPG detector draws .2 amps
Single dual bulb light (198 bulbs) 2.3 amps
Single dual bulb light (LED panels) .1 amps
Light fixture over dining table (4 198 bulbs) 4.5 amps
Single reading light over bed (1 198 bulb) .8 amps
Recessed Halogen lighting, living room (6 lights) 8.4 amps Full on
2.1 amps Fully dimmed
Recessed Halogen lighting, over sink (1 light) 1.4 amps Full on
.4 amps Fully dimmed
Recessed Halogen lighting, over couch (3 lights) 4 amps Full on
1.2 amps Fully Dimmed
Refrigerator 1.2 amps
Furnace (Suburban SF35) 7 amps
Water Pump (Shurflo Smart Sensor 5.7) 11.9 amps running, 12.6 max
Exterior porch lights (3 incandescent bulbs) 2.8 amps
Exterior Porch Lights (3 LED bulbs) .8 amps
http://www.forestriverforums.com/for...itor-5436.html
NOTE: Nothing here mentions an inverter. Converting 12 volt DC to 120 volt AC requires HUGE amounts of amps. Watts DC is Watts AC. For example, a 1500 watt coffee maker running on the Inverter pulls 125 amps from the battery. That will suck the batteries dead before you can say "Is it still perking?"
04-20-2011, 07:37 PM
#25
Reading all the threads on this subject I haven't seen anyone mention solar charging panels. If a person really wants to get away from the hookups and find the beauty this country has to offer will solar panels buy you a few more days. With that said what size charging system is adequate for one battery verses a two battery system?
Getting the camper out for a trip next week.
Solar Cell, Solar Panel, Solar PV, Solar Products, Charge Controllers, Solar Trackers
Great Price for a fair sized panel.
04-20-2011, 09:08 PM
#26
Once again- I greatly appreciate your wealth of information!
That 1.2 amps; is that a 3 way fridge running on 12 volt power? Or is that a 2 or 3 way fridge running on propane? Just asking because I know my fridge is 2 way only; so when boondocking I will be using propane for the fridge.
Wolf Pup T16P owner
04-20-2011, 09:12 PM
#27
as far as i know, the only 3-way fridges anymore, are only in popups or A-frame popups.
so, everything else has 2-way only.
maybe back in the day, TT's had 3-way but not for a long time.
04-20-2011, 09:22 PM
#28
Well, I am using a "2 way" I guess.
It has a 120VAC mode and a Propane mode. The 1.2 amps is the "propane mode" dc current draw. Is that what you mean?
When burning propane to cool the fridge, the computer control board and flow fans use DC power.
04-20-2011, 10:26 PM
#29
Yep- that's exactly what I meant. Once again; just counting my amps so there are fewer surprises the first time out.
Does the fridge run constantly, or does it just cycle like a home frisge would? I'm just thinking 1.2 amps as a constant draw would mean less than 72 hours of boondocking once you figure everything else in.
Wolf Pup T16P owner
04-21-2011, 06:48 AM
#30
On propane that is pretty much a constant draw. On AC, the current varies because it uses an AC heating coil to make the heat, not gas, as there is no "compressor" like your home fridge. The AC also has a "defrost" feature that you can turn off with the little switch in the freezer section. (top of door area). That uses AC power when the switch is on and only work on AC.
72 hours is about all I get with 150 amp hours of bank; PROVIDED I do not use the TV too much (inverter item).
04-21-2011, 10:24 AM
#31
Villa Estate 392FLFB
My thoughts exactly. get a solar panel and another battery. put the panel up on the roof or something and let her charge all day!
One state/province at a time!
04-21-2011, 12:30 PM
#32
There are threads here about the advantages and disadvantages (there are a few) of Solar panels.
If you all want to talk about Solar, we should start a new thread.
04-21-2011, 12:43 PM
#33
running the TV is not fair game. the idea is no generators. running your TV will only serve to irritate your neighbors and possibly get you booted from the campground.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
04-21-2011, 12:46 PM
#34
They better come armed heavy!
04-21-2011, 07:48 PM
#35
"Neighbors"?.......I thought this was the "boondocking" section!
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
04-21-2011, 08:15 PM
#36
TV- are you talking Television or Tow Vehicle? I ask because both have been discussed in this thread.
Wolf Pup T16P owner
04-21-2011, 08:47 PM
#37
My experience at Yellowstone depending on the time of the year while visiting, you may not need the furnace at all. I personally sleep better if it is cool or even cold in the room and use blankets or sleeping bags, in the morning it may be brisk but often warms up comfortably within no time. If you are used to 72 degrees day and night and live in a warm climate, this may not work for you.
My last trip to Yellowstone we woke up to varied weather including snow flurries, rain and bright sunshine, we used the heater in the morning but not at night.
The previous trip was the first week of October in a popup and we never used the heater at all.
#38
Holy Cow Ken I just got that.
I was talking about the Television not the truck!
04-28-2011, 06:13 PM
#39
wow herk....there are some darn good prices there, on a per watt basis
This one gets you below $2/watt: http://www.solarblvd.com/p2416/Everg...fo.htmlhttp://
2021 (Dec) Dynamax Isata 30 FW Xplorer
04-28-2011, 06:24 PM
#40
My friend ordered a panel and controller from them while we were in Key West. They shipped quickly and it worked perfectly on arrival. Well packed for travel, the shipping packaging weighed more than the contents. Shipping was "dear" but it did arrive promptly and safely so I think it was worth it. Even with the shipping it was still cheaper than its closest competitor.
