02-25-2017, 10:45 PM
Generator for Infrequent Trips - Rockwood Mini Lite 2509S (13,500 BTU AC)
Hello!
We recently purchased our first travel trailer. It's a Rockwood Mini Lite 2509S (13,500 BTU AC).
We plan to go on approximately 3-4 trips per year where we will not have access to electric hookups.
Those trips will be 2-3 nights long each.
What is your best recommendation for a generator for us? I hate to purchase something super expensive and unnecessary for very infrequent trips where we won't have hookups. However, I don't want to regret a purchase either
Thanks for your recommendations,
Erica
02-25-2017, 11:08 PM
For me, personally, the Honda is the only way to go. But that's me. In your situation, you need to look at the Champion generators with the invertor. If you haven't yet, you'll be mildly surprised with the prices. Should meet your needs!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
02-25-2017, 11:16 PM
Originally Posted by ebell619
Hello!
Erica
If you plan on using it in a campground, then you need an INVERTER generator. But they cost more than the noisy open frame generators. To dependably run the a/c, 3000w or more would be needed. That'll start around $700 and up.
If you aren't going to use it in a campground, then a cheap open frame generator will work. The Champion 3500/4000w one is very popular and cost around $300. But be aware that it'll be noisy and it'll weigh 100lbs.
02-25-2017, 11:57 PM
Do not waste your money buying a cheap generator. Go with Honda inverter eu3000is or two eu2000is. I have a 3000 but it's heavy. I can't lift it by myself to put it in the back of my truck. With the 2000, you can by two and these are lighter.
Good luck!
02-26-2017, 01:54 PM
Best one I found and works perfectly is the Briggs 3000 watt generator. It has no problem running anything in the trailer and is still quite quiet and I can still move it around by myself thanks to the two handle top design and the telescopic front handle. It's also very reasonably priced.
02-26-2017, 01:59 PM
Of course everyone has their favorites and for their reasons. I'll just toss in what I learned from going thru the same. Looked at them all and of course Honda is a Honda... Best you can get but with a price to go along with it. I settled on two smaller champion INVERTER generators with the parallel kit. Has a standard RV Hookup and with both running more than enough power to run everything in the trailer. Best yet each one is small and lightweight and easy to pick up and put in the truck. When running you can stand next to them and have a normal conversation. In fact the AC unit that they are running is usually more noisey than the generators. As with all inverter generators they only run as fast as needed to power the load.. So when the AC cycles off the generators are just about at an idle. Cost wise for me, it was cheaper for the two lighter units than one big Honda. So far not one problem at all.
02-26-2017, 02:23 PM
generator
I have a Honda 3000. Like said earlier, it is very heavy, but very quiet. Stayed in an overflow lot at a campground one fourth of July. No hook ups and my refrigerator for some reason wouldn't run on propane. Generator was so quiet they let me run it all night. It is very efficient on gasoline. Will run refrigerator and air conditioner easily all night on one fill. It is expensive for use only 3 or 4 trips a year. I guess for that I would look into a 2000 watt unit. The ones enclosed in cases are very quiet and less than $1000. Look in your dealers parts area. They probably have a nice one on display.
02-26-2017, 02:41 PM
I have a 2012 rockwood signature ultralight 8288ws with a 15k ac unit. My champion 3100 inverter runs it just fine.
02-26-2017, 07:37 PM
You don't necessarily need a 3k genny to run AC. Review this thread for info: http://www.forestriverforums.com/for...0i-102347.html
You won't be able to run the AC and Microwave or hair dryer at the same time though.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
02-26-2017, 07:59 PM
Generator
Look for Ryobi 2000, work for the pass 2 years for me and cost nothing compare to Honda or Yamaha, Big name = big buk.
02-26-2017, 10:56 PM
generator
Hello!
Erica
Just buy one at costco. If you don't like it take it back.
02-26-2017, 11:02 PM
For three to four trips a year you might try a rental yard for an inverter generator or borrow from a friend.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
02-26-2017, 11:16 PM
Might be a good idea, I found out the hard way that you either need to use Trufuel Ethanol Free Fuel or run all the gas out. In a couple of months of non-use the gas gummed up the carburator in our Honda. Now I run it empty but the Honda shop told me I could use the Trufuel Ethanol Free Fuel and it would store for a long time with out gumming stuff up.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
02-27-2017, 12:16 AM
Ryobi inverter generator winterisation
Empty the gas tank and open the engine cover and loose one turn the screew under the carburator and the carburator flote empty it self.
It take 5 minutes.
That`s it, no gum in the carburator!!
02-27-2017, 09:41 PM
It take 5 minutes.
How do you empty the gas tank on a Honda 2000i? I was thinking that but the only way I could figure out to empty the tank was to take a bunch of the covers off and disconnect the fuel line. I could not see a good place to get to the fuel line through the access panel. I guess I could cut the fuel line and and a tee with a valve, hmmm got me thinking now. Anyway is there an easy way to drain the tank? Thanks for the info.
MISSION COMPLETED!
02-27-2017, 09:45 PM
Who Dares, Wins
Thats about the way to do it, that I have found. I suck it out the best I can then run it until it dies then do the screw thing under the carb.
Before I converted my home backup generator to natural gas I burned gas in it. Left a hair in the tank and the ethanol ate right through the rubber hoses. Nasty stuff.
2015 Chevy HD D-Max
2022 Impression 315MB
02-27-2017, 09:57 PM
My two eu2000is are 11 years old. I've never drained the fuel. I always use Sta-Bil fuel additive and use higher octane fuel. I also start them up about every two months if we haven't used them. No need to drain the fuel.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
02-27-2017, 10:23 PM
Generator threads are always entertaining.
My favorite posts are always how the Honda's are so much better than all the others.
I find that humorous at best.
Carry on, I have my popcorn in the microwave (that is running on my Champion Inverter.)
02-27-2017, 10:27 PM
Who Dares, Wins
Yes they are... But my Honda can still beat up your Bolly...
The only thing out there when I bought my Honda 11 years ago was either Honda or Yamaha.. Honda service was 4 miles away, Yamaha 150 miles away...
2015 Chevy HD D-Max
