Old 04-10-2024, 09:40 PM   #1
New to Boondocking
Hi there. Relatively new to RVing and have never boondocked. I plan on stationing my 2019 25" Ultra Lite on a lot I own which has a well but no power. May have power a couple of weeks after I arrive. I have a Westinghouse 4500 generator and a single lithium battery. I have a number of questions.
1. I have a port on the side of the RV which says it can handle a 20-amp solar panel. Any suggestions as to panels I should get and what I should expect in the way of charging ability?
2. I would prefer to keep the RV stationary while I'm on my lot probably about a month. ThÝs means bring potable water to the RV and taking the poop into town or moving the RV more than I might like. There is a town with an RV park around 10 miles away, It will be just me, my girlfriend and two big Labs. My TV is a Suburban. What sort of equipment should I get to accomplish this and how should I use it, or should I do it some other way? I am 66 years old and am capable of lifting some weight but probably not a 30 gal, water tank! Thanks in advance.
Montana Joe is offline   Reply With Quote
Old 04-10-2024, 10:45 PM   #2
bikendan's Avatar
Moved thread from the General Community Discussion section to the Boondocking sub-forum since the OP's questions are specific to that sub-forum and not general questions.
Old 04-10-2024, 11:28 PM   #3
Solar panels are relatively cheap put some on your lot as a ground array
Get a good mppt controller for the size of your array
Wire the controller directly to the battery ignore the solar wire that is probably too small
Use a good connector at the Barry so you can disconnect if you have to move
Check your local laws about constructing a small septic tank an leech field
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 05-17-2024, 07:01 PM   #4
Joe,
Wired for solar sells RVs but are not of much use.
You need around 200-400 watts for a typical system. That means a new MTTP controller and proper sized wiring like Aussie mentioned.
For fresh water, you might invest in a 12 volt pump to get water from your truck tank to your RV tank. You could build a 12 volt solar system to run your well. Ranchers do that all the time.
There are tanks that can be used for black and grey water removal.
ppine is offline   Reply With Quote
boondocking
