Congrats on your decision to test the rig. Step two now is to learn your system. Do you have an inverter that takes the 12V battery power and makes 120VAC? Is your refrigerator a residential (120VAC only) or absorption (120VAC or LP)? Your water heater is probably 120VAC or LP, do you know how to control which heat source it uses? Do you have some sort of battery level meter (not sure what came built in)? You need to ID the batteries to determine how much capacity you have to work with.
A shunt power meter is a valuble tool for testing. A volt meter can tell you the voltage of the battery but unless you are checking a battery that is just sitting (not in use) your reading won't be too much of a level indicator.
I encourage you to learn your system. Best done before you need to know the system, sitting in a cold dark rig in the middle of the night.
2019 Palomino Solaire 147X
2013 Ford F150
