Old 06-20-2020, 11:45 AM   #1
Wire size
I don't know if it is right or wrong but Coachmen used 6AWG wire for my battery connections. I am going to be changing over to 2 6volt batteries and am curious as to what size wire I should use as the jumper between the 2.
Should I stick with the 6AWG or should I go a little heavier such as 4 or 2?
cliffy49
2018 Catalina Trail Blazer 26TH
2016 Ford F-150 Eco-Boost, Max Tow
cliffy49 is offline   Reply With Quote
Old 06-20-2020, 05:08 PM   #2
I use this for my DC wire sizing on my Roo and my sailboats.
http://circuitwizard.bluesea.com/
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is online now   Reply With Quote
Old 06-21-2020, 05:41 PM   #3
Wire size
My rule of thumb is every foot of wire adds resistance. Thicker wire adds less. So I always use a bigger wire than called for especially when I am living off that battery bank.
2021 Alpha Wolf 23 RD-L
2015 F250 diesel, air bags
42 gallon diesel aux tank
SantaFe big sky is offline   Reply With Quote
Old 06-21-2020, 07:09 PM   #4
If adding wire (Like the jumper for 2 6V batteries) or replacing, go as large as is practical. If you ever add a large inverter the wire you replaced/added won't have to be replaced again.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 06-21-2020, 11:48 PM   #5
rk06382's Avatar
I like to use this chart:
Robert
2018 FR3 28DS - Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 06-22-2020, 05:35 AM   #6
2 feet of #6 is capable of handling 100amps, gonna be pulling 100amps thru your system ?
TheWolfPaq82 is offline   Reply With Quote
Old 06-22-2020, 06:16 AM   #7
for short jumpers between the batteries use the same size #6 nothing gained going bigger
Mike134 is online now   Reply With Quote
Old 06-22-2020, 12:35 PM   #8
Thumbs up
Thanks everyone. I went with a short pc. of #4 wire.
cliffy49
