Old 06-14-2024, 09:20 PM   #1
About a 1/2 ton pu as a toad
Anyone pulling a standard 1/2 ton pickup with your C class? The units I'm looking at are a 27' Ford 450 chassis Coachmen, 26 rs, 7,500 tow capacity, pu is 5,200 lbs. so I know on paper it should be ok, but wanted some real world feed back how rig behaves. I know lighter is better but trying to avoid buying another toad if possible. Thanks in advance
dmall is offline   Reply With Quote
Old 06-18-2024, 07:35 AM   #2
While I can’t remember it being a class C or Class A. I have seen several full sized trucks to include a Ram 3500 with a Cummins pretty sure that one was behind a Class A. Might see if there is a dedicated Coachman forum to to widen your opportunity
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 06-18-2024, 08:10 AM   #3
Thanks !
Old 06-18-2024, 09:05 AM   #4
Chuck_S's Avatar
I just gotta see how this turns out...
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-18-2024, 09:39 AM   #5
D W
D W's Avatar
-- Chuck
X2. What is the GVW of the Coachman loaded?
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 06-18-2024, 01:30 PM   #6
Ford E 450 Coach, 27'
From mfg. data
Gvwr - 14,500 lb
CCC - 3,310 lb
Hitch rating - 7,500
Pickup wt - 5,200
Old 06-18-2024, 01:46 PM   #7
bikendan's Avatar
From mfg. data
Gvwr - 14,500 lb
CCC - 3,310 lb
Pickup wt - 5,200
Just because the hitch is rated for 7500lbs, doesn't mean the Motorhome is rated to tow that much. Is the hitch receiver factory or aftermarket?
Old 06-18-2024, 01:50 PM   #8
Chuck_S's Avatar
What's the Ford, the camper's, GCVWR?
-- Chuck
Old 06-18-2024, 02:10 PM   #9
Oaklevel's Avatar
I have seen it often behind a Class A not sure that I have seen a full size pickup behind a Class C.
Am following this thread too to see where it goes......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 06-18-2024, 03:26 PM   #10
Factory installed hitch, their rating, pkup would be less than 80% of rated capacity. Gcwr is 20k per mfg of Rv, pulls my 4500 lb wrangler well, though its mainly been on flat land
toad
