Old 11-13-2017, 09:44 PM   #1
Added washer/dryer combo to chaparral 360 IBL
I couldn't find a post here back when I installed this in April. Been to busy camping since then to sit down and write this up.
I chose to vent out the left side as it was the shortest path out. I ran the pipe down and under the cabinet. Under the left side closet is like a shoe storage area. You can gently pull those panels out to gain access to the side. You can then measure from the front cap edge to get an idea where you need to drill the hole. I measured outside and then came inside and made sure it was all clear. Drilled the pilot hole from the inside out. Then drilled from the outside in with the hole saw. More time consuming than anything. Getting down beside the bed where you can see what you are working on is the most difficult part. I did not get fancy on replacing the lower panels. I just put a few screws back in them. You can't see it unless you lay on the floor anyways. Figured if I used screws I could take it off if I needed to access in the future.
ID:	156403   Click image for larger version
ID:	156404   Click image for larger version
ID:	156405   Click image for larger version
ID:	156406   Click image for larger version
ID:	156408   Click image for larger version
ID:	156409   Click image for larger version
ID:	156410   Click image for larger version
natedawg is offline   Reply With Quote
Old 11-14-2017, 12:36 AM   #2
Selective Curmudgeon
Halfmast's Avatar
I've got a while to go before my 360IBL gets built/delivered but I'd like to install the washer/dryer combo.
Thanks for posting.
2016 Ford F350 Diesel Dually
2020 Sandpiper 368FBDS
Halfmast is offline   Reply With Quote
