Originally Posted by Bama Rambler
Those hold down bolts should be torqued to 45 in/lbs or about 4 ft/lbs. So they're not supposed to compress the gasket very much.
I would probably tighten them a little and see if that fixes the problem.
Thanks for the response, I torqued them to 45 in/lbs which is much tighter than they were. Hopefully no more issues.
