Originally Posted by tjbaker
The 12V cigarette port with 2 USB-A ports in the pass through works as expected, both on 110 and on the battery. The one on the side of the bed inside the camper is not quite right though. The two USB-A ports work ONLY when connected to 110. The cigarette port does not work at all, not on 110 nor 12V DC. I can't see the back side of the cig/usb panel from the pass through as it is boxed in. Ideas on how to trouble shoot this?
It may be normal for those USB ports to work on 110.
However, the cigarette/power port should work. Do you have an inverter on that rig? Usually the power ports are installed near the bed to power a CPAP machine overnight. There may be a switch somewhere to connect it directly to the battery.
Are you the original owner?
