01-02-2018, 02:19 PM
Awning Make/Model 2015 Catalina 323BHDS
Can anyone provide the awning make/model for a 2015 Catalina 323DHBS?
Thanks!
01-08-2018, 11:16 AM
Can anyone with this model look at the tag on the inside of the right hand awning arm and provide a part number?
01-08-2018, 06:31 PM
Is it an automatic awning? Most likely a dometic.. Thats what coachmen uses AFAIK, and thats whats on mine..
If its a manual awning let use know..
https://www.dometic.com/en-us/us/pro...wning-_-164427
2020 Ram 1500 classic 5.7l hemi 3:21 rear 8 speed
2019 Palimino XLE 24 RD
01-08-2018, 10:41 PM
Originally Posted by Lawrosa
That is correct. It is a Dometic 9100 electric awning. The issue I’m having after speaking with Dometic is they don’t know what the part number is supposed to be. They need the information off of the tag on the outermost arm when the awning is retracted and I need to replace that arm because it doesn’t exist on this unit.
01-08-2018, 11:02 PM
Thats crazy as they are all the same arms... I have this with black arms...
Dometic is messing with you maybe....
01-08-2018, 11:09 PM
Possibly! I was able to speak with Forest River and get their part number but they only sell the complete set of arms, right and left.
01-08-2018, 11:12 PM
what part # did you get? Post it...
01-08-2018, 11:23 PM
01-08-2018, 11:32 PM
01-08-2018, 11:37 PM
I can look at mine tomorrow if I remember and get the part # off it... How long is yours so I can measure mine ...
01-09-2018, 05:49 AM
Top of the assembly to the bottom is 55-5/8” if I remember correctly. It may be 65-5/8 but I’m pretty sure about the 55-5/8.
01-09-2018, 05:51 AM
That’s the one I’m thinking would work too. Forest river sent the following:
C01289717 AWNING, ELECTRIC 21' W/BLUE LED CHARCOAL 916FT21B.501UL $472.85700
01-09-2018, 09:14 AM
That would be fantastic. Dometic just came back with part number 3312487.006u
01-09-2018, 01:38 PM
The arm tag says this.. Its about 64 1/4 long...
These are black or brown I believe.
mfg # 8952002.400UL
mfg/pnc 958643597
sku 9108853270
The tag on roller says this.. Its a 15 ft awning
mfg # 916ft15b501ul
mfg/pnc 958684654
sku 9108918561
01-09-2018, 01:49 PM
mfg # 8952002.400UL
mfg/pnc 958643597
sku 9108853270
mfg # 916ft15b501ul
mfg/pnc 958684654
sku 9108918561
Thank you for checking yours, it is very much appreciated!
01-09-2018, 02:19 PM
Hope it helps. Let us know the outcome...
It seems my # is for the pair and I assume there are individual part #'s for left and right. But seems you have to buy the whole arm with shock, slider, wire, ( if that side) etc etc.. Very expensive...
01-09-2018, 02:40 PM
It seems my # is for the pair and I assume there are individual part #'s for left and right. But seems you have to buy the whole are with shock, slider, wire, ( if that side) etc etc.. Very expensive...
That is correct for the 895 part number to my knowledge. The right side number from Dometic has been ordered. I'm hoping to have it by the weekend. Fingers crossed it will be correct.
01-15-2018, 09:19 AM
This part number arrived yesterday. It is the correct part. Installed in the snow and it works perfectly.
01-15-2018, 09:26 AM
That's great! This forum comes thru again!
Thanks for the update.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
