Old 03-09-2018, 11:52 AM   #1
Azdel Tar Removal
What products should be used to remove tar from Azdel fiberglass exterior and what should be avoided?
hilfikerkg is offline   Reply With Quote
Old 03-09-2018, 12:12 PM   #2
glsimms's Avatar
Someone correct me if I'm wrong, but I think Azdel is an interior wall product?
As far as the tar removal, if it hasn't been on there long, I would try Goo-Gone.
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 03-09-2018, 12:28 PM   #3
Empty Nesters
KenandCarol's Avatar
Azdel is the composite panel that Forrest River uses on at least all their Class C Motor homes of not more. It is the complete panel from the fiberglass outside to the foam interior to the inside panel and integrates into the metal framing.
https://www.azdelonboard.com/
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 03-09-2018, 12:32 PM   #4
Thurman's Avatar
Azdel is an exterior wall product. "Coachmen RV uses Azdel Composite Panels to replace wood in the RV sidewalls. Azdel Panels are constructed using a blend of polypropylene and fiberglass, creating an extremely strong and lightweight wall."
Thurman is offline   Reply With Quote
Old 03-09-2018, 12:51 PM   #5
retireearly's Avatar
Could also try a clay bar (for detailing cars) if you don't want to use a solvent. I found it worked well for paint overspray, bug guts, and even stray sealant the factory had been sloppy with. I actually clay bar'd the whole motorhome recently prior to waxing. I use a little water spray to make dragging the clay easier.
2017 Forester 2291S
2015 Honda Accord on Master Tow Dolly
1999 Jeep Cherokee flat tow
retireearly is offline   Reply With Quote
Old 03-09-2018, 01:04 PM   #6
Fresh Tar removal=Awesome! Old Tar=Turtle Wax Tar Remover! Neither will Hurt your Exterior Wall! Youroo!!
