Closed Thread
Old 03-20-2019, 10:56 PM   #21
BriaBeck's Avatar
Originally Posted by kujosp View Post
Repeat after me, before this gets out of control like the thousand other posts: It does not matter if it is the positive or negative side. That is the only answer.
+4.
I put mine on the Negative following the logic that normally when you disconnect a battery, you disconnect the Negative first to prevent shorting your wrench to ground as would be possible if you disconnected the Positive first.
Remember that the electrons flow from - to + also... so if you look at it that way, the Negative side is the HOT side.
But, as was stated earlier, it doesn't matter in the grand scheme of things.
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline
Old 03-20-2019, 11:14 PM   #22
I wonder if the same people who put disconnect switches on the negative side of the battery also put fuses and circuit breakers on the negative side of the load. Again, it doesn't matter except for the poor slob that buys the RV wired that way and tries to figure it out.
babock is offline
Old 03-21-2019, 12:40 AM   #23
Originally Posted by BBDAWG View Post
I don't want to re-open this much discussed topic BUT
IMHO - If You disconnect the "+" cable, there is NO possible current flow in any of the wiring circuits.
However, If You disconnect the "-" cable, the "+" side wiring is and remains hot all the time and any wiring or anything that touches a "-" negative wire or any part of the chassis will cause a spark or cause an item to begin operating should the on/off switch is also set to "ON" and could actually cause a fire.
Again, IMHO, I choose disconnecting the "+" cable (at the battery) to prevent any possible electrical current drain.
NOW, it would be really nice if both the "+" and "-" were disconnected at the battery and I was asking if there is such a switch available? one throw and both cables are disconnected.
There is no way it could cause a spark if you disconnected the neg cable even if you ran a wire from a positive terminal to the frame as there is no way it could complete a circuit back to the battery.
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline
Old 03-21-2019, 01:50 AM   #24
Just as confused as you
Scrapper's Avatar
Some rv's have more than 1 wire connected to the positive post at the battery. The only time any of us have seen more than one wire connected to the negative post is when there has been a ground problem and to fix it another wire is installed. It doesn't matter if you install the battery cutoff switch on the positive or negative cable as long as all the wires going to that battery post is connected through the cutoff switch.
Richard & Jill
Camping since 1989
Everyone gets confused at some time, some are better at hiding it than others.
Scrapper is offline
Old 03-21-2019, 09:27 AM   #25
bedubya's Avatar
Originally Posted by firemedicmark View Post
Harbor Freight - Battery Disconnect Switch - Item#97853, Cheap, simple and small enough to fit inside battery box.
But to disconnect, you need to open your battery box. I mounted this in the top of my battery box:
https://www.amazon.com/Zoostliss-Bat...s%2C189&sr=8-6
But you also need a short battery cable. I put it on the (+) side.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
bedubya is offline
Old 03-21-2019, 10:52 AM   #26
That's why you move all the wires on the post to the switch! Not a big issue.
babock is offline
Old 03-21-2019, 01:17 PM   #27
kujosp's Avatar
Why would anyone do that? The simple solution was already given.
kujosp is offline
Old 03-21-2019, 03:03 PM   #28
LOL...there should be no more than 2 wires. There really should only be one. Unless some hack added more wires. SO...if it's simpler to put a circuit breaker in a negative lead, would you do that as well?
On my Coachmen Freedom Express, the way the power is distributed with those circuit breakers that the battery goes to is a mickey mouse way of doing things. On mine, one of the first thing I got rid of are those crappy breakers and put in a real circuit breaker inside the trailer right after the batteries and the disconnect switch. Won't even talk about how ridiculously small the cables are.
babock is offline
Old 03-21-2019, 05:13 PM   #29
kujosp's Avatar
You’re confusing DC with AC.... DC is simply closed or open. It doesn’t know where the break is located...
kujosp is offline
Old 03-21-2019, 05:22 PM   #30
How many more months till camping season !
MR.M is offline
Old 03-21-2019, 05:43 PM   #31
Flybob's Avatar
It makes no difference which terminal is disconnected as disconnecting either one breaks the circuit. The concept of disconnecting the negative terminal is left over from auto maintenance. This is due to the fact if you are disconnecting the positive terminal and the wrench slips and hits the body/frame you will get a good arc and possibly a burn. If you disconnect the negative side and the wrench slips and hits the frame nothing happens. If switching the positive side, you have to make sure that you are switching all the wires. On some TT the tongue jack/light are directly wired to the battery and if not disconnected someone can hit the light switch and drain the battery. Also if the negative terminal is disconnected and you touch a hot wire to the frame nothing happens as the frame is now floating.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Flybob is online now
Old 03-21-2019, 06:00 PM   #32
As is AC and not sure why you even bring AC up.
babock is offline
Old 03-21-2019, 06:00 PM   #33
Camping season is year round!
babock is offline
Old 03-22-2019, 07:59 AM   #34
Thumbs up Great Discussion - Thank You All
I have learned there is not, in our camping/boating industry, any form of a switch that will cut both sides of a battery at one time. I have also learned that it may not even be necessary to do so, which is why no one has create such a switch.
I am good with the information posted, Great Discussion - Thank You All
18 Coachman Freedom Express 322DS
17 Nissan Titan Crew Cab V8 gas
BBDAWG is offline
Old 03-23-2019, 10:31 PM   #35
BriaBeck's Avatar
Another reason to put the battery disconnect in the Negative cable is it will cut power to your power tongue jack when you turn the disconnect off. If you put the disconnect on the positive cable, your jack will be powered all the time.
Brian & Becky
Champion 3500
BriaBeck is offline
Old 03-23-2019, 10:44 PM   #36
Retired Old Fart
dward51's Avatar
Yes, pulling the cable on the negative side of the battery is a good idea on any negative ground vehicle. Especially if you have a diamond plate aluminum lower cap like I do on mine. One turn of the wrench too far on the positive side and it is possible to arc it on the diamond plate, which is also screwed into the frame at the bottom. That's why I always disconnect negative side on mine. And do negative first if taking both battery leads off.
I learned that lesson about 50'ish years ago working on my first car, a 1966 Chevy Nova. Lots of pretty sparks.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline
Old 03-24-2019, 12:05 AM   #37
I want EVERYTHING turned off with the disconnect switch. No need to have ANYTHING still powered. Putting on the positive side does that as well. If there is one lead on the positive battery post and that goes to your disconnect switch, how does the jack remain powered?
Not sure why people think it's necessary to have the jack, break away switch, radio or even the LP detector still powered. When you have a switch disconnecting everything, you are assured that you can work on anything and it isn't powered. You are also assured you have ZERO draw.
babock is offline
Old 03-24-2019, 12:08 AM   #38
We are talking disconnect switches, not pulling a lead off the battery.
Go to any RV dealer and look at every trailer and RV that comes from the factory with a disconnect switch and see if its on the positive or negative side of the battery. You will find 100% of them are on the positive side.
babock is offline
Old 03-24-2019, 09:48 AM   #39
If I bought a trailer with a negative disconnect switch, I would be wondering what other non standard "features" were added. DC circuit breakers in the negative paths of loads too? After all, it works electrically!
babock is offline
Old 03-24-2019, 12:35 PM   #40
Ditto Ditto
BBDAWG is offline
Closed Thread
battery, cat, location, switch
