Old 12-11-2017, 09:11 AM   #21
If you don't have the black tank flush on your unit, get one of the tank flush wands and use that to prevent/remove buildup.
I bought a camper once that I later found had lot of solids in it, it was a bit of a pain to clean out. I filled it with water, let it sit for 3 days then dumped it. I had access to a pasture that had some woodchuck holes so I could get away with dumping at my leisure. I made my own wand with an old piece of water hose and a piece of copper pipe. Closed of one end of the pipe and drilled a hole in the side of it near the closed off end, attached the hose to the other end and clamped it on. Stuck that down the toiled and started blasting water in while turning and tilting the wand to flush out what remained. It took a little while but it did the job.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
DougW is online now   Reply With Quote
Old 12-11-2017, 09:25 AM   #22
John Dorsey's Avatar
Yeah I have the flush just a series of mental mistakes. Full timing can make a simple mistake like failing to close a valve compound quickly. Then realizing in the middle of trying to use the flush nothing is coming out. That doesn't leave much wiggle room to do anything from the top.
2016 Brookstone 395RL
2013 Ram 3500 DRW
2001 Winnebago Brave
1998 Rockwood popup
John Dorsey is offline   Reply With Quote
black, black tank, tank
