Old 07-09-2021, 01:10 PM   #1
Nick Danger's Avatar
Blackstone Griddle
The Mrs wanted a 17" Blackstone griddle with cover and stand - so I did what I was told and got one. My questions are - Where do most store it during travel? And are there issues specific to the griddle that I should consider before I just put it somewhere?
Once I got all the pieces I quickly realized the following -
1) It's heavier than I expected.
2) It doesn't fit in the slide out that holds the coleman grill that came with camper.
3) I already have a lot of stuff in the back of the truck and in pass thru.
Of course I can easily rearrange our stuff and make it fit but was hoping for something I hadn't thought of that was sensible. Also should it not be next to anything that I need to be aware of?
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
2004 Heritage Softtail Harley Davidson
Nick Danger is offline   Reply With Quote
Old 07-09-2021, 01:16 PM   #2
Luv mine.
I have a toyhauler so I just lay it in the corner of garage. And yes it is heavy..
Trksr is offline   Reply With Quote
Old 07-09-2021, 03:57 PM   #3
Mine does fit in a storage compartment. I have the 22" with the lid and table legs. I store the griddle separate from the box. By standing it up on its edge, it takes very little floor space. When I move it around, it's always in 3 parts - stand, box, griddle. This helps a lot with the weight.
Try to keep the griddle clean before storing. Otherwise critters will be interested.
Keep the griddle itself somewhere it'll stay dry. Water, especially on the non-seasoned parts will cause rust. Rust and food are not a good combo.
Hope that helps.
Skip12 is offline   Reply With Quote
Old 07-09-2021, 05:53 PM   #4
Cousins
My 17” Blackstone stays in my outdoor kitchen shelf. I clean the griddle and turn it upside down in the burner. It sits neatly all by itself and doesn’t move when traveling. I wipe the griddle down again before I use it. No cover or legs on mine.
2015 Forest River Cherokee Grey Wolf Limited
2011 F150 Supercrew Ecoboost Lariat 4WD
Eddie and Catherine is offline   Reply With Quote
Old 07-09-2021, 06:01 PM   #5
Oaklevel's Avatar
We bought the storage bag to keep it in. It stays on the floor for travel and under the camper on our totes if bad weather.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-09-2021, 06:25 PM   #6
Thank you all for the good feedback. Hadn't hought of standing on its edge. Will look into the bag suggestion also.
Retired USAF
Centerline TS WDH
Old 07-09-2021, 06:29 PM   #7
Never would have thought to turn griddle over and setting on burners. Genius!
Retired USAF
Centerline TS WDH
Old 07-10-2021, 12:40 PM   #8
265RBSS fits on shelf above the slide out shelf
I have a Blackstone 17" with lid and I find it will fit on the shelf above to the left of the fridge sideways. Now I don't have the stand just the grill. I also have to take off the propane adapter that I have to use it on the trailer. I used a foam kneeling pad to go between the griddle and the fridge to protect them. Works good. Maybe there is room above it to put the stand (assuming it comes off easy)
(I also don't use the coleman grill thing. Its out of the trailer. I use the space to store stuff.)
Tim & Nancy Cahoon
Southfield MI
Coachmen 2021 APEX Ultralight 265RBSS
F150 XLT 3.5L EB
Tim-Nancy-C is offline   Reply With Quote
Old 07-11-2021, 08:10 AM   #9
Can you run 3800 fps?
We have the Blackstone Tailgater Combo with the Griddle and Propane Grill in one. Yeah, it's a Heavy bugger. Well built, though. We love using it, and I store it in the back of the pickup. Pretty full back there, with the Generator, Straw, Solo Bonfire, Blackstone, Firewood, Blocking, and tool kit. I just like to be prepared. Air Force training, I guess. Safe Travels!
Edward & Pamela
2019 Ram 2500 BigHorn 6.4L Gasser
2017 Coachmen Catalina 263RLS "Priscilla - Queen of the State Parks"
Camping together for 45 years!
SniperDroid is offline   Reply With Quote
Old 07-11-2021, 08:24 AM   #10
We carry our 22" in the back of our toad, along with the camping chairs. We unload and set it up when we get to our destination.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is offline   Reply With Quote
Old 07-12-2021, 06:26 AM   #11
Adaptability is the key to Air Power.
Retired USAF
Centerline TS WDH
Old 07-12-2021, 10:12 AM   #12
i have a 208 bhs, and last week i mounted a 17" blackstone with lid onto rails in the outdoor kitchen. I had to push the fridge all the way over so that it would fit. The fridge does not open all the way, maybe 80-85 degrees open vs a nice 90... but it doesn't really cause any issues.
i took out the existing rails and used some 250lb rated heavy duty rails. 22inch. Currently the black stone clears the trailer by 1-2inches.. i did a lot of heat tests this weekend, and it doesn't heat up the side of the camper at all.
i looked every where for drawer slides that would open longer, but couldn't find any. Realized on the weekend that I could just add another set of drawer slides, and mount two sets of slides. I am going to get some 500 lb 18" slides, and do just that. It should put the black stone about 20" away from the side of the trailer, hopefully with no jiggle (there is no jiggle now, its rock solid on the 22" slides).
It is awesome just to slide it out, cook, let it cool off, and then slide it back.
oh, i re-did the inside of the storage as well.. i took everything out, laid down two 2x4s, and screwed them into the floor.
i'll take some pictures once i'm done if anyone is interested.
dbender is offline   Reply With Quote
Old 07-12-2021, 11:52 AM   #13
Absolutely interested. Looking forward tot eh pictures.
Retired USAF
Centerline TS WDH
Old 07-14-2021, 12:59 PM   #14
Glowplug
Just read a previous thread about Blackstone Griddle and resetting the gas regulator to use a 20 LB tank instead of the little 1 Lb.
Comment by Glowplug was right on target for me. Thanks.
Retired USAF
Centerline TS WDH
Old 08-01-2021, 06:28 PM   #15
dbender I also have a 208. I would love to see what you did on this. I want to upgrade the Coleman before our next trip. Do you have some time to post your pics?
BallisticApex is offline   Reply With Quote
Old 08-03-2021, 09:43 AM   #16
Sure, i'll post some at lunch time today. I've been waiting to see if everything is working properly before posting..
Just got back from camping for the last 4 days. Griddle and slides work really well. I'm going to make a little shelf that fits on the rails next to the blackstone to give me a place to put spatulas/etc.
I'm working on a set of "leveling" pieces to get the griddle super level, because even though the trailer is "pretty good".. the extensions over emphasize any issues and i get pooling on the griddle..
Old 08-03-2021, 09:48 AM   #17
I just got an adapter and the longer propane line for mine so I can hook into the existing propane connection on back of my trailer. That is already a low pressure line. Works great. Didn't have to reset anything.
2020 Palomino Solaire 316RLTS
2017 F-250 6.2L
Richbo69 is offline   Reply With Quote
Old 08-03-2021, 03:57 PM   #18
Excellent! I'll need to see if I can do this myself. Thanks.
Retired USAF
Centerline TS WDH
Old 08-04-2021, 04:08 PM   #19
i posted pictures of my setup in the 208BHS owners thread, its on page 27
Old 08-04-2021, 05:06 PM   #20
U.S.ArmyVeteran's Avatar
Being the dutiful Husband. I also zipped off an order to Amazon. We have had it for almost a year now. The War Department loves it! She loves it so much, I have yet to clean it. My only mission is to hook it up to the Trailer Propane. And put it back in the truck. AFTER SHE CLEANS it, EMPHASIS Intended!!
The old BBQs and I do mean several of them are hidden in the shed awaiting a Garage Sale.
I Love Our BlackStone :-)
U.S.ArmyVeteran is offline   Reply With Quote
black
