Old 06-12-2021, 05:48 PM   #1
Can't get heater on
OK, so I am new to trailers and maybe just a dork. I have the propane on, but I can't get the heater to come on. It's dometic, but I can't find any info on it.
The tab that slides with the temperature settings doesn't slide. I've tried pulling it forward and pushing backwards before sliding, but it feels like it would break. What am I doing incorrectly??
BabyTruck is offline   Reply With Quote
Old 06-12-2021, 06:23 PM   #2
Do you have a picture of the thermostat?
Crispie0206 is offline   Reply With Quote
Old 06-12-2021, 07:10 PM   #3
bikendan's Avatar
Sounds like they have the cheap analog thermostat.
Old 06-12-2021, 07:22 PM   #4
Yes, it's a cheap analog thermostat.
Name:	P1020033 - Version 2.JPG
Old 06-12-2021, 08:07 PM   #5
is there a separate on off switch on it like some have or just the main temp lever ? pull the cover off and see what the hang up is
MR.M is offline   Reply With Quote
Old 06-12-2021, 08:07 PM   #6
I don't know why it wouldn't slide but it seems like you would be able to pop the cover off to get a better look. If it's stuck at a low temp it won't turn obviously.
Old 06-12-2021, 08:10 PM   #7
rracer5's Avatar
X2. Pull the cover off. It sounds like something is got the temp lever hung up.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-12-2021, 08:15 PM   #8
There is an on/off on the bottom. It's on.
Old 06-13-2021, 02:00 PM   #9
Following for resolve.
2019 Forest River Coachman Freedom Exp 248 RBS
Jeep Grand Cherokee pulls like a dream.
First trip, 10K. Delaware to Del's Restaurant at the top of Route 66 to California, back to Delaware without a hitch or glitch. Living the DREAM!
"Brain Farts sometimes go unnoticed until further Inspection " If they only had a smell.
campers302 is offline   Reply With Quote
Old 06-13-2021, 05:23 PM   #10
Danesville's Avatar
Do you have your 12 volts on
Danesville is offline   Reply With Quote
Old 06-13-2021, 05:41 PM   #11
I have to go to the storage yard later to see if I can get the cover off. I'll post if that's where the problem lies.
Old 06-13-2021, 05:42 PM   #12
I don't have a battery disconnect. Is that what you're referring to? The batteries are on a trickle charger.
Old 06-13-2021, 05:44 PM   #13
Danesville's Avatar
Yes as you need 12 Volts to run the furnace
Old 06-13-2021, 05:45 PM   #14
The first thing I do is. Hmmm what is that. Oh yeah I take off the thermostat and either jump the two wires or remove them from the thermostat and put them together. That lets me know if it is the thermostat. Last time I had trouble just had to set reset switch on furnace. That took removing 12 screws on outside of Motorhome.
BDenn is offline   Reply With Quote
Old 06-13-2021, 08:50 PM   #15
OK. I AM a complete dork! I went into the trailer, took a better picture, removed the cover, took another picture, and I wore my glasses this time. I don't know what the top tab does, but the bottom one has what I believe is the fan speeds or maybe amount of heat. As you can tell, I have no experience with this type of thermostat. Anyway, it was waaaaay to hot to even try to turn on the heater. I'll have to wait until early morning and open all the windows to cool it down first.
Thank you EVERYONE for your input! I'll keep trying.
ID:	256940   Click image for larger version
Old 06-14-2021, 09:00 AM   #16
Top tab is on-off switch bottom temp slide
Old 06-14-2021, 11:25 AM   #17
Thank you. The top tab does not move. I didn't see anything not allowing it to move.
Old 06-14-2021, 01:18 PM   #18
that top tab needs to go to the left to turn the unit on, it is currently in the off position. if you look real close on it it says off with an arrow-> my parents 2004 surveyor had this style of thermostat, you felt like you were going to break it turning it on...
2017 Primetime Crusader Lite 27RK
2008 Ford F350 King Ranch 6.4l
Bogieboy is offline   Reply With Quote
Old 06-14-2021, 01:47 PM   #19
Still following
Old 06-14-2021, 04:15 PM   #20
OK, Bogieboy...... I'm going to go out and see if I can push that stubborn tab to the left!
If I break it, I guess I'll buy a digital thermostat.
Thanks!
heater
