03-06-2018, 08:47 AM
Check your frame bolts
I was checking the pressure on a tire yesterday and while down there I put my hand on a frame bolt, and I could spin it with my fingers. I got out a ratchet and socket and tightened it up, and proceeded to the next one. None of them were tight. Even the two bolts that hold the steps on were loose, one very loose. These are the bolts on the outside edge, on the frame supports. This makes me wonder what may be loose under the enclosed underbelly where nothing is accessible unless you remove it. Do these bolts work loose or were never tightened? I'm thinking the latter. So check your bolts.
03-06-2018, 08:53 AM
good you found that with that many loose I think you are correct in assuming they may never have been tightened correctly from factory.
Retired Navy
2016 Flagstaff 26 FKWS
03-06-2018, 09:24 AM
Always Learning
I wonder if this is the type of thing that should be reported to the NHTSA?
From the 2017 Prime Time owners manual (I know yours isn’t a Prime Time, it’s just what I have handy):
03-06-2018, 09:36 AM
Attachment 164403
It could be if others chime in with loose bolts. Or it could be an isolated incident where mine just did not get the final torque. They were not all finger loose but none of them were what I would consider snug or adequately tightened.
03-06-2018, 10:11 AM
Always Learning
Makes sense. I think the idea of NHTSA is that they keep track to determine if things are recurring or not.
I do think on the new rig, I’m going to make a point to drop the under belly and inspect it. Not during PDI, but soon after. It’s just such a hassle, though!
03-06-2018, 05:08 PM
Most of mine were loose, too, all the way around the outside edge.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
03-06-2018, 06:01 PM
Following this . . . .
McCormickJim
2017 GT 31L5
03-06-2018, 06:15 PM
Guess I will this weekend when DW and I do some spring cleaning to the TT.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
03-06-2018, 08:00 PM
Thanks Crabman for the heads up. I'll be checking mine the next time at the camper.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
03-06-2018, 08:42 PM
I just checked all mine and they were all loose almost falling off of my Forest River Patriot limited edition 2018
03-06-2018, 08:55 PM
Always Learning
(cough) you ALL need to report this to the NHTSA! (cough)
03-06-2018, 10:42 PM
I'd like to check mine but I'm unclear on what and where are the "frame" bolts?
2018 Reflection 5th Wheel
2017 F-250 Lariat 4x4 6.7L Diesel
TST 507 TPMS - Titan Disc Brakes
Furrion Observation Camera
Goodyear Endurance Tires
03-06-2018, 10:53 PM
I noticed this winter that the front steps were loose. I found the bolts loose and finger tightened them because I had no ratchet at the time. My 26RLWS is 1yr old and I have not seen many issues so far. You now have me worried.
I planned to drop the underbelly this spring anyway to do some insulation. I will be checking the remaining bolts and then report my findings. I know the other steps were secure.
Thanks for reporting so I knew to look!
03-06-2018, 11:43 PM
They are the bolts that are under the perimeter of the trailer that connect the sides of the trailer to the outside supports of the frame, and are a few feet apart the length of the trailer except where a slide is located. There are two also holding on the outside of the steps, for example and a starting point. It's actually the nuts that you will see from the bottom and that is what was loose. Maybe I can get a pic tomorrow. There are self tapping screws that hold on the underbelly, these were not in question, nor the running gear bolts.
03-06-2018, 11:57 PM
On the plus side this job of tightening the bolts takes all of 15 minutes at the most, I just laid on my back on the ground and moved from bolt to bolt. There are no bolts where the slide is.
03-07-2018, 11:27 AM
It just so happens I found loose outter bolts yesterday while repairing my side skirt. Forest River Cherokee 33’
Rob & Kathy
South Florida
2017 Cherokee 274VFK Travel trailer
03-07-2018, 02:47 PM
Have to wonder if these bolts were not tightened at the factory or if they come loose while being towed from all of the jarring and such.....
Gerard
Blue Ox SwayPro WDH
03-07-2018, 03:16 PM
Might these perimeter bolts be into the wooden sill plate? If so would they be loose from the sill plate drying out and shrinking some?
03-07-2018, 04:59 PM
That’s a very good possibility MtBiker. They are into the wood sill. If that’s the case they need to start using thread lock to stop this. What happens when They all come loose and the owner never finds it? Box and frame separation ? Ugh. Lol. I don’t want that problem
Rob & Kathy
South Florida
03-07-2018, 05:07 PM
I am not sure about others but my stairs which are loose are into the metal frame. I plan to check the rest still.
