Old 05-13-2020, 08:56 AM   #1
Check Your Weight Specs
Well I found a discrepancy on the stated dry weight on my 2017 Catalina. The side label with the tire information has the dry weight as 3493 lbs while the Vin sticker on the front left side of the frame stated the dry weight as 6042 lbs. That's just over a 2500 lb difference, yikes. If I was purchasing tires using the lower stated weight I would be in trouble.
I have already contacted Coachmen about it and they are supposed to be sending out a revised weight and tire sticker. The actual dry weight of the camper is supposed to be the higher number of 6042 lbs.
Just a heads up for everybody, be safe.
Eddie2002 is offline   Reply With Quote
check, weight
