Old 10-03-2020, 07:01 PM   #1
Coachmen 370FL pin box
Is Lippert 1621 pin box is the standard pin box style on most 5th wheels? I am new to 5th wheels, and I was offered a Rota-Flex pin box, and it fits a Lipper 1621 pin box. Thanks.
kglazier67 is offline   Reply With Quote
Old 10-03-2020, 09:15 PM   #2
NMWildcat's Avatar
That is one of the most popular. Usually the model is either stamped into the metal or is on a sticker. Or you can take some measurements and compare to this chart: https://www.etrailer.com/faq-measuri...l-pin-box.aspx
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-03-2020, 09:29 PM   #3
We don't have our 5th wheel yet, so I don't know what is on the metal. I might go look at a very similar model and see what I can find out. Thank you.
Old 10-03-2020, 09:51 PM   #4
NMWildcat's Avatar
You could also call the dealer or the manufacturer tech support line for info.
Old 10-03-2020, 10:01 PM   #5
I did call our dealer - they didn't know without researching it.
Old 10-04-2020, 04:25 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
The 1621 can be different weight capacities. My OEM one on my Wildcat was rated 12000 lbs. I switched it for a Moryde RPB rated 16000 lbs. Both the OEM and the replacement are Lippert 1621 compatible.
So if the one you are being offered has at least the same or better weight rating you should be ok.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
coachmen
