Old 05-11-2020, 05:00 PM   #21
Not surprised it is a little lower on the passenger side. That's where your kitchen and fridge are.
babock is offline   Reply With Quote
Old 05-12-2020, 05:56 AM   #22
Mine does too
I'd really be interested in what you find out. I have the exact same trailer and when I put it in storage last fall I noticed the same thing. Looks like it leans slightly to the passenger side. Took a quick look at suspension to see if I has a broken leaf spring or not but couldn't see anything out of place.
KingJames is offline   Reply With Quote
Old 05-12-2020, 08:32 AM   #23
I'm new here, but I have experience with something like this with an old R-Vision Trail lite. The floor on the driver's side of my old trailer became soft and was actually "sagging" around the frame on the outside edge. The trailer wasn't constructed very well and I actually became afraid it would fall apart while towing. I'm not sure how your trailer is constructed, but it might be something you want to look for. Good luck.
jdhog1977 is offline   Reply With Quote
Old 05-12-2020, 09:39 AM   #24
That was my initial thought but he says that there is only a 1/2" difference between the axle and frame on each side. If excessive weight on one side was causing compression on the leaf springs, should there not be more of a difference?
___________________________________
2015 Brookstone 315RL
2016 GMC Sierra 3500HD Diesel 4x4 CC LB LEMON
Hatchee is offline   Reply With Quote
Old 05-13-2020, 02:11 PM   #25
Following
campers302 is offline   Reply With Quote
Old 05-13-2020, 02:51 PM   #26
My Vibe has leaned to the drivers side ( the slide out side) since day one. I assume it’s due to slideout weight.
bjaspud is offline   Reply With Quote
Old 05-14-2020, 08:46 AM   #27
Shackle straps on the equalizer worn?
Water/waste tanks empty?
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 05-25-2020, 06:38 PM   #28
jvg
coachman trailer leans to side
had same issue. Took to service they found a couple of the suspension shackles broken low side. U couldn't see it easy. Replaced and back to normal
jvg is offline   Reply With Quote
Old 05-25-2020, 07:24 PM   #29
Good deal. I'm glad you are all fixed up.
Old 05-25-2020, 07:43 PM   #30
Trailer springs are inexpensive. Replace them.
One leaf might have broken.
IDguy is offline   Reply With Quote
Old 05-25-2020, 08:43 PM   #31
ADVICE...
Find a spring dealer in your area....take it to a professional!!!
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
Old 05-26-2020, 02:43 PM   #32
Hold on, if the axle measurements are nearly identical and the tire to floor measurements are different that would point to a potential bearing failure on the low side. I would pull the hubs and check them.
Dragonmaster is offline   Reply With Quote
Old 05-26-2020, 10:04 PM   #33
I had the same issue. Spring sag. I had custom leaf springs built. Zero problems now.
vman7932 is offline   Reply With Quote
coachmen, trailer
