Old 01-30-2017, 10:05 PM   #21
I actually emailed coachmen about it. Here is the response:
Good afternoon,
The seal is cut away at the rollers to prevent the seal from contacting the rollers and tearing them as the room cycles in and out. You will also see the seal cut away at the arm which operates the arm mechanism and again, this is done to allow the arm to cycle in and out without damage to the seal. We hope this answers your question as to why the seals are cut away.
We do not have a modification that eliminates this issue, if modifications are made, you would want to insure that that interference with the rollers and arm is avoided.
triptaker09 is offline   Reply With Quote
Old 01-30-2017, 11:03 PM   #22
Well, I guess our "modification" using the foam water hose insulation has an "implied endorsement" from Coachmen. 😉
Last Train is offline   Reply With Quote
Old 01-31-2017, 04:46 PM   #23
glsimms's Avatar
Originally Posted by Last Train View Post
Well, I guess our "modification" using the foam water hose insulation has an "implied endorsement" from Coachmen. ��
You should be getting some sort of royalties......
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
freedom express, slide
