Originally Posted by fipntdot
I had the same thing happen yet. Haven't bothered with a solution yet. On a side note, I was thinking of lining the metal rack for the table with some sort of rubber because it is scratching up the table.
Poke around at Lowe's or Home Depot and look at the various sizes of hose and tubing in the plumbing department. Find a size that would just fit over the rack, Make lengthwise slide along one side of the tubing and snap segments around the rack elements.
(You can also use material from the auto parts store: hose in sizes from small vacuum hoses and winshield squirter hoses up through heater and radiator hoses. Also the "wire loom" tubing which is already pre-sliced for snapping around cables.)
