Old 09-28-2022, 08:27 PM   #1
Fresh water drain
Does anyone know where the fresh water tank drain is on an Apex Ultralite 245 bhs. It has an enclosed underbelly. I know where the low point drain plugs are, but canít see the fresh water tank drain.
jhudohmet is offline   Reply With Quote
Old 09-29-2022, 09:18 AM   #2
Welcome to the forum!
I don't know the answer to your question, but do you have a wet bay that might have the drain?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-29-2022, 09:58 AM   #3
I would crawl under the trailer and look at the area behind the wheels (possibly between the wheels) on the driver's side. That's where your water connections are and it stands to reason that the freshwater tank drain would be located somewhere close to the fresh water tank gravity fill connection.
NavyLCDR is offline   Reply With Quote
drain, fresh water, water
