Old 09-14-2017, 05:40 PM   #1
Furrion TV
Can anyone share a secret on connecting to park cable and to Furrion TV in Chaparral. First try.
Have coax cable run from park box to TV because I was not sure that connection in control center is correct. Have tried fitting marked CABLE/SATELLITE and LIVING ROOM PORT.
Ran channel scan Even thought it was locked
No luck
DesAl1991 is offline   Reply With Quote
Old 09-17-2017, 12:22 PM   #2
SeaDog's Avatar
Have you checked on the outside of your rig on the service side for your cable connection? this should allow you to connect the cable from the park to your rig and with the booster off run a channel check.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-17-2017, 12:40 PM   #3
Be certain that the amplifier is off, otherwise no signal will reach the TV.
Bocamo
Chapparal lite - 266Sab
Bocamo is offline   Reply With Quote
Old 09-17-2017, 09:23 PM   #4
Thanks for the ideas. It seemed to be a channel scan issue. All is well.
