Old 05-18-2022, 03:44 PM   #1
BG19's Avatar
Galley grey tank valve will not open
I have a 2017 Coachmen chaparral 392mbl.
When i pull the galley grey handle, it moves in & out without difficulty, in fact it feels normal (no extra friction felt... not particularly loose or tight)... but the valve will not open to release grey water. Have not ever had any difficulties with any of the valves. Am thinking that the push/pull rod may have come loose at the valve possibly. Anybody had similar issues? Thank you.
BG19 is offline   Reply With Quote
Old 05-18-2022, 04:03 PM   #2
Mr. Dan's Avatar
Oh, yes! The line that appears to connect the slip cable center wire and the set screw is only a wire in the background.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
Old 05-18-2022, 10:23 PM   #3
BG19's Avatar
Attachment 273490
Thank you so much Mr. Dan. From my research I suspected something like this but certainly was not sure. Very much appreciative for the photo also... will be very helpful. I hate to cut the underbelly... but here we go, right. Thanks again. Safe travels. bg
tank, valve
