Old 08-26-2020, 08:21 AM   #1
Gas Quick Connect
I have a 289TBSS and just noticed the gas connect near the door. Do I need a special adapter to use it with stove?
chrispt is offline   Reply With Quote
Old 08-26-2020, 09:10 AM   #2
PhD, Common Sense
Probably. Check with your local bottled gas dealer. Bring your RV in along with the appliance you want to connect.
I learned the hard way that there is no standard for connections. They had to special order a hose with the correct connectors on both ends.
Also, if the connector you found on your RV has a regulator between the connector and the gas supply, do NOT have a regulator between the connector on the RV and the appliance.
eye95 is offline   Reply With Quote
gas
