Originally Posted by Capt StevieJ
I have a 2019 Coachmen Chaparral Lite and love the 5th wheel. I am at a loss as to how to fill the fresh water tank from a 5 gallon Jerry can. I had a Jayco trailer before this unit and it had a Gravity feed connection that we would use when doing extended boondocking. The photo below is the water panel associated with the usual hose connections outside the trailer.
How do I fill the fresh water tank with out a city water connection available.
If no gravity fill port I'd invest in a pump setup like shown in numerous posts on this forum. Then use it to pump water into the tank through the city water hookup with the pictured valves in the "tank fill" positions.
Use a pump just like the one installed in your RV and then you'll have a spare should anything happen to installed pump.
That kind of pump should empty a 5-gal water can in under 2 minutes.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
