Old 09-19-2021, 09:28 PM   #1
Lesson learned Severed 7 pin cable
Hello all
Have a 2019 248rbs and coming home from vacation I somehow severed the 7pin trailer cable. Lesson learned and fixing the problem was how the cable is crimped at the junction box shown below. The remedy I am putting in is another box so I don't have to redo the crimps in the junction box. One I finish it, the new box will be mounted on the inside on the frame. This will save a person from undoing the crimps and crimping again. Going forward if this happens again I just take the old cable off and put on a new cable.
I bought the cable and box from Amazon at the link below...
https://www.amazon.com/gp/aw/d/B07L8...b_b_prod_imageClick image for larger version
ID:	263088Click image for larger version
ID:	263089Click image for larger version
ggrimm01 is offline   Reply With Quote
Old 09-20-2021, 01:17 AM   #2
Wow. A thing of beauty compared to the rats nest in most trailers.
Good find.
MtBiker is offline   Reply With Quote
Old 09-20-2021, 06:11 AM   #3
JWood422's Avatar
And Click image for larger version
ID:	263098itís made with decent copper!
JWood422 is offline   Reply With Quote
Old 09-20-2021, 07:39 AM   #4
Good find.
Except it sounds like he is leaving the rats nest and just adding another splice point for the 7 pin cable. The original junction is not sealed at all and those nice pretty crimp splices will be a corroded mess eventually. Better to replace the metal indoor rated junction box with the new box and install a new umbilical cord.
WY Husker Fan is offline   Reply With Quote
Old 09-20-2021, 08:26 AM   #5
Yes, it looks like he is taking the old 7-pin cable from the original junction box and running it into the new junction box. I agree, personally, I believe it would be better to completely eliminate the old junction box entirely.
NavyLCDR is offline   Reply With Quote
Old 09-20-2021, 12:31 PM   #6
SetauketJeff's Avatar
There are a few threads about this. The metal boxes are for interior use and not waterproof and should be swapped out for the waterproof plastic ones. If you use a long enough 7pin connector and cable, you should be able to terminate directly into a waterproof plastic box just under and behind the frame of the "A" frame in front (such that the waterproof plastic junction box is located behind the frame and under the body of the camper).
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2007 Chevy Trailblazer LT 4X4 Tow Package, Locking Rear, 157K Just pulled 16FQ 1,044 miles. Husky Centerline TS32215 WDH Round Bar 400-600Lbs.
CURT 51180 Echo Bluetooth Brake Controller (Love it!)
2004 Ford F-150 STX 4X4 Tow Package, 206K For Pulling TT in the sand
SetauketJeff is offline   Reply With Quote
Old 09-20-2021, 12:37 PM   #7
Gas-tight crimps
Pretty sure those Buchanan connectors qualify as gas-tight crimps. Bell Labs did a bunch of research on it, probably 70-80 years ago, and discovered that if the crimps were gas-tight, the box didn't have to be weather-tight.
Larry
Larry-NC is offline   Reply With Quote
Old 09-20-2021, 12:48 PM   #8
Search 7 pin Trailer Cord and you will find them in all lengths. Some even come the with waterproof junction box. This will help you neaten up the mess that you have.
One example: https://www.amazon.com/MICTUNING-Hea...2159862&sr=8-5
2021 Wolf Pup 16FQ.
Old 09-20-2021, 12:50 PM   #9
Those winged wire nu in the same box are nothing-tight.
cable
