01-24-2018, 02:13 PM
#21
I use the Viair 400P-RV (150psi max), works great on my 110psi tires and hitch. I keep it in the battery compartment connected all the time.
Tim & Eileen
2016 Cedar Creek 34RL towed with a 2017 Silverado 3500HD Diesel
01-24-2018, 02:24 PM
#22
Denver, CO
Originally Posted by TitanMike
I personally hate the 12V compressors. I would rather have a 120V model with a 150 PSI capability and can fun from my 3500 Watt Generator.
Gets the job done faster and less chance of burning up some wires.
Absolutely avoid any compressor that plugs into the cigarette lighter. Almost every one I've seen ends up burning up the plug itself because they put out such a small volume and have to run 30 minutes to an hour to pump up a flat tire.
The Viair clips on the battery, shuts off when up to pressure and works fast, so try it you will like it. I got no room for a 120 volt compressor of any kind as many class b and c rigs. Viair is perfect.
2017 Fuse 23T
01-24-2018, 02:26 PM
#23
Stanley makes a great one. I just bought it at Sams Club for $69. It WILL pump up to 100psi. I used it to top off my RV tires to 80psi. Worked fine.
It also will jump start your battery and has an internal charger, plus USB ports and an LED light.
Great item.
01-24-2018, 03:47 PM
#24
We have an off brand 12V, 100PSI compressor purchased through JET.COM and had an opportunity to use it to inflate a flat spare tire to 70PSI. It worked, but took a while and the hose connection at the compressor was extremely hot.
01-24-2018, 04:16 PM
#25
Itching to go . . .
I love my Viair 88P 120 psi. @ Amazon for about $64.
Never had a problem. I keep it, a tire repair kit, and a pressure gauge in an ammo box.
2018 T21TBHW Aframe
2017 F150 Lariat Screw FX4 3.5 EB 10 spd w/MaxTow
01-24-2018, 04:38 PM
#26
Lowe's has a unit that works off both AC and DC power for about $45.00. PSI up to 90...
01-24-2018, 04:57 PM
#27
I've had this for several years......so/far so/good.....
Unencumbered By The Thought Process
01-24-2018, 05:42 PM
#28
I have Slime 40022 12-Volt Digital Tire Inflator I bought at Walmart
and it works great. I run it off of the trailer battery with an alligator clip wire connector.
01-24-2018, 07:38 PM
#29
Harbor Freight has a good one and it's inexpensive.
01-24-2018, 08:53 PM
#30
Slime 2X Heavy Duty Tire Inflator 40026
I just bought the Slime Slime 2X Heavy Duty Tire Inflator 40026
https://www.walmart.com/ip/Slime-2X-...40026/20573327
In testing it puts 80 psi into my TV tires pretty easily. I think it will handle the 110 psi 5er tires. Before I bought it, I read other reviews that said it would, but it's not going to be quick about it. Like all lower-priced units, it does have a max run time after which a cooling period is required. It feels solid and reliable.
I would recommend it to a friend.
01-25-2018, 01:24 AM
#31
Tire inflator
Go to Lowe's, for a little over $125 you can buy a combo Jump start, Tire pump, cell phone /Tablet charger, nicely portable . My travel trailer is also in storage with no A.C power. Just need to recharge the battery after use.
Hope this helps.: Rosecreek
01-25-2018, 07:33 AM
#32
Newly Retired
No cig lighter
Northern tool has a good one for about $160. Direct battery connections.
Save it for emergency as much as possible.
Forget the cig lighter type. You will blow fuses and be left flat.
01-28-2018, 10:39 PM
#33
X2 on viair. I have two of the heavy duty units and use them. Frequently.
X2 on direct battery connect. While at 50psi you shouldn't need it, the mid- duty and up compressors will up will always have them.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
02-04-2018, 07:46 AM
#34
Perhaps someone could clear up the "direct battery connect" reference for me. Is this a wire harness that remains on the battery posts all the time? And you plug the compressor into it?
I need a 12v compressor that can be used when on the road with 5th Wheel hitched to the truck. And it doesn't seem I can get a long enough cable run to reach the trailer tires if powering off the truck batteries. And when hitched, getting to the trailer batteries for power is problematic - there is limited room.
02-04-2018, 10:20 AM
#35
The direct connect type compressors typically use alligator clips to connect the compressor to the battery posts. This ensures max current to the compressor.
The other type of compressors use the cigarette/12v socket inside the vehicle.
Regarding the distance between the battery and the wheels -- it is power cord length and air hose that separate the typical car-type compressors vs ones for trailers.
On my bumper pull, I solved this problem by hooking to travel trailer battery (to shorten the distance) and adding one additional air hose.
On my 5er, I got a different compressor with substantially longer hoses (can connect to my truck battery and it will reach back to the trailer spare tire.
02-04-2018, 10:44 AM
#36
code.org
Viair 300P
I got the Viair 300P. Seemed like the best bang for the buck. I connect directly to the trailer's 12v batteries and the cord / hose are long enough to reach the trailer's tires and the TV tires.
It is also a compact unit not needing a lot of storage space and comes in a nice bag. It worked well on our two long trips last year.
Appears to be on sale at Amazon at the moment:
https://www.amazon.com/VIAIR-30033-3...rds=viair+300p
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
02-04-2018, 12:09 PM
#37
Originally Posted by moff34
Thanks for the heads up. I got one.
As with all compressors, when you need more reach, add more hose, not more wire.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
02-04-2018, 12:24 PM
#38
I recently bought the 88P. It didnt come with a bag though, i bought a cheapie one seperately...
2017 Freedom Express 271bl
2013 Silverado Z71
02-04-2018, 12:25 PM
#39
Two weeks ago I picked up one of these at O'Reilly Auto Parts.
https://www.oreillyauto.com/detail/s...air+compressor
$89 and it uses cord clamped directly to battery terminals.
It filled a 205/75-15 LR D tire from FLAT to 50 psi in just over 5 minutes. Max capacity 150 PSI.
Comes with a nice little carry bag too to keep things neat while sitting in the storage compartment.
I was holding out for a 120 Volt unit but couldn't find one reasonably priced and I suddenly needed a portable for a dump trailer. This one worked so well I'm somewhat of a convert, as long as the unit has direct connecting battery clamps.
02-04-2018, 12:50 PM
#40
If one has a really good set of jumper cables (I have a set designed for professional road service trucks) one could use them as a power cord extension. One end clamped to the battery and the other end clamped to the proper color alligator clip. My battery cables are 1/0 wire so I doubt that there will be much voltage drop.
I would PREFER more hose, always, but I'll use what I have in a pinch
