I have a 2019 Freedom Express Pilot 19FBS and I cannot find where the manual crank location is found. Luckily it has never failed but I want to know where it is just in case. Can anyone help me locate?
LCI 12volt motor and brake unit is under the couch. They can help with detail. If I recall you unplug the 12v brake wire next to the motor and use a 1/2 socket to spin the slide in or out.
Try the Forest River company web page in the component manuals library. Look for the Happijac booklet. Your slide motor and override are under the couch inside the trailer.
It involves unplugging the motor brake wire then spinning shaft in or out (cordless drill and 1/2 socket) or ratchet wrench. Then reconnect brake wire. Be careful as there is a small sensor switch on the rail under there and it’s delicate.
