Old 07-31-2021, 03:49 PM   #1
Retired Air Force
Mounting wall TV
Mounting a wall mount TV in my Apex Nano 191rbs How? Are the studs aluminum? Will a stud finder work? How thick are walls? for screw length
zeenith is offline   Reply With Quote
Old 08-01-2021, 07:37 AM   #2
SeaDog's Avatar
there is usually backing installed in the area that your coax wall plate for the TV is located. Yes a stud finder will work as long as its a quality stud finder and not the magnetic type. If there is no backing plate in the wall you can make your own and attach it to the studs and then the TV bracket to that. I would use no screws longer then 1.25" good luck
Retired Navy
2016 Flagstaff 26 FKWS
mount
