Closed Thread
Old 04-19-2021, 06:43 PM   #161
Originally Posted by pat5150 View Post
Regarding my TT symptoms....We shall forget the swapping of the breaker...
Having done my troubleshooting to the main panel...Are there things in the main panel that can fail and cause this, while, having everything else work on regular non-gfi power.
I had this problem plugging in a shed with an extension cord to a breaker panel. I had to take the green wire off the ground bus in the breaker panel for it to work. I still don't know why that worked for me though.
mstred is offline
Old 04-19-2021, 06:52 PM   #162
bikendan's Avatar
Originally Posted by Michael3807 View Post
Turn the breaker off to the battery charger or unplug it see if that solves your problem.
If you had read through the thread, you would have seen that the OP found the problem, almost 40 posts ago:
https://www.forestriverforums.com/fo....php?p=2539050
bikendan is offline
Old 04-19-2021, 07:27 PM   #163
If you are new to camping ,an had everything in the camper turned on at the same time:ie, the ac ,fridge on electric, water heater on electric, and so on. WILL trip your breakers. Can't have everything going at the sametime.
pitzhauler is offline
Old 04-19-2021, 08:56 PM   #164
Originally Posted by pitzhauler View Post
If you are new to camping ,an had everything in the camper turned on at the same time:ie, the ac ,fridge on electric, water heater on electric, and so on. WILL trip your breakers. Can't have everything going at the same time.
I think bikendan's post just prior to yours bears repeating:
NavyLCDR is offline
Old 04-19-2021, 09:16 PM   #165
Is you neutral and ground on the same lug bar.
graystone is offline
Old 04-19-2021, 09:23 PM   #166
May as well close this one... no one reads.
Days Camped: '18=51 '19=58 '20=110 '21=94
5picker is offline
Old 04-19-2021, 10:41 PM   #167
Nix
I think this can also happen if you have heater on with an empty tank (dump on pack up day and forget). The element will warp and then short to tank. Keep an eye on that guy.
Nix is offline
Old 04-20-2021, 07:59 AM   #168
lesptr's Avatar
You are right. Reading comprehension is lost.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now
Old 04-20-2021, 08:05 AM   #169
Thanks to the FRF community for helping this member get their problem fixed. We are going to go ahead and close this thread now as the solution was posted a few days ago and we no longer need guesses as to what the problem is.
Solution:
https://www.forestriverforums.com/fo...ml#post2539050
The OP can contact the site team if any updates are needed.
Thanks!
Iwritecode is offline
Closed Thread
trailer
